1. brothamoveson's Avatar
    So I install the update and after its done my phone reboots about every 3 minutes. I cleared the cache partition that didn't help. In safe mode it does not reboot so I tried removing apps thinking one of the newer installs may be causing the problem didn't help. So I decided to just totally wipe it and start over. Everything worked fine no problems after re-installing everything. Then once I switch batteries the rebooting starts all over again. Anyone have any ideas on how to fix this.
    03-24-2015 09:33 PM
  2. brothamoveson's Avatar
    Never mind it was the SD card took it out no reboot, tried different SD cards it rebooted.
    Posted via Note Pro 12.2
    03-24-2015 10:12 PM
  3. dbansal's Avatar
    I'm having similar trouble with my AT&T Galaxy S4. after upgrading to lollipop my phone keeps on rebooting randomly. does a factory reset helps to solve this issue? the issue I have with factory reset is that I have earlier encrypted my device (due to my work applications requirement) and now I cannot actually see option to decrypt my phone or my SD card.
    I'm not sure if after doing factory reset I'll be able to use my SD card or not?
    05-01-2015 05:13 PM
  1. Replies: 56
    Last Post: 05-06-2015, 12:03 AM
  2. Does the m8 draw more power when at low battery level
    By android jack in forum HTC One M8
    Last Post: 03-29-2015, 06:56 AM
  3. Sound keeps muting, but volume is at maximum
    By debsawyer in forum Samsung Galaxy Note 4
    Last Post: 03-26-2015, 01:43 AM
  4. random reboot after moving apps.
    By Dragon905 in forum Ask a Question
    Last Post: 03-25-2015, 04:48 AM
  5. How can I fix my soft bricked Galaxy S4 (at&t)?
    By RoAcH007 in forum Samsung Galaxy S4
    Last Post: 03-24-2015, 11:57 PM
