1. Tomster88's Avatar
    I just updated to lollipop 5.0. 1 on AT&T note 4. I'm using Chrome as my browser but I can't find the tabs anywhere. I can't find where to switch between different tabs. Does anyone know how to do this now and lollipop? Thanks!
    03-24-2015 11:59 PM
  2. vinnie_boombhats's Avatar
    I believe chrome tabs are now treated like the scrolling apps in recent apps. There is an option to turn it off.
    03-25-2015 12:05 AM
  3. beagle82's Avatar
    Tabs can be found in your recent apps. To create a new tab, tap the three dot menu and select new tab. If you want to revert to how it was pre-lollipop, under settings, switch off the merge tabs option. But, you should get used to it pretty quickly.
    03-25-2015 12:11 AM
  4. Tomster88's Avatar
    Thanks guys! I also figured out how to turn that feature off in the settings. You can disable it under merge tabs and apps and it goes back to the regular way the old chrome treated tabs in 4.4 KitKat. Thank you!
    03-25-2015 12:30 AM
  1. S6 Edge going to be like the active versions?
    By exile0229 in forum Samsung Galaxy S6 edge
    Last Post: 03-26-2015, 08:56 AM
  2. How do I install Java?
    Last Post: 03-26-2015, 02:35 AM
  3. How do I change my keyboard back to all black on my Galaxy S3?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-26-2015, 02:33 AM
  4. 5.0.1 Lollipop Installed Tonight!
    By babylon5fan in forum Samsung Galaxy Note 4
    Last Post: 03-25-2015, 07:22 AM
  5. How do I change the apps position on my Galaxy Nexus?
    By gfederline9 in forum Ask a Question
    Last Post: 03-25-2015, 01:59 AM
