1. okanobi's Avatar
    Is anyone else experiencing the heart rate light coming on whenever the device is in your pocket or pressed against something that is not your finger? Even putting a pillow case against it is enough to make it come on. I've even tried slowly lifting my device up and I can see the red light as I pick it up...Maybe I never noticed before but every time I put in my pocket red light shines through...battery died fairly quick today and I want to say that's the culprit.
    03-26-2015 06:56 PM
  2. SpookDroid's Avatar
    Known issue with Google Fit and Samsung Heart Rate Monitor. Just uninstall Google Fit or disable it and the issue goes away.
    akpmehta likes this.
    03-26-2015 06:58 PM
  3. okanobi's Avatar
    Is this after 5.0.1 update that this issue shows up? Like I said, I never recall seeing that light ever before and my battery always lasted all day. Guess I'll uninstall Google Fit then not that great anyway.
    edit:
    Just so there is no mystery that was the cause. Uninstalling Google fit is the solution.
    03-26-2015 07:04 PM
  4. iGalione's Avatar
    I was just going to looking into this, as I noticed this was going on and when I wear my phone on my hip or put it in my pocket or even on its back, the sensor stays on. I just changed batteries and reset my phone and it seems to have gone away. But if it comes back and remains an issue, I will do as you guys mentioned and rid of google fit... #bummer
    03-26-2015 10:54 PM
  5. ChemMan's Avatar
    It is probably just checking that you are not an android. It seems to get over it when it sees you are human and quits searching after a day or so. Or so I have seen.
    lol
    03-27-2015 12:01 AM
  6. Bosbouer's Avatar
    lol
    Actually the other way round. If it stops you are confirmed to be android
    SpookDroid likes this.
    03-27-2015 06:34 AM
  7. SpookDroid's Avatar
    edit:
    Yup, it's a Lollipop issue. It wasn't there before.
    03-27-2015 11:50 AM
  8. ChemMan's Avatar
    So did anyone look at your pocket and ask "Are you happy to see me?"
    lol
    03-27-2015 12:51 PM
  9. Ntchwaidumela's Avatar
    I believe AT&T released 5.0.1 just to get it out, without regard for bugs commonly experienced with that version. That version has known issues that, along with 5.0.2, supposedly have been addressed with 5.1. Hopefully, my carrier, TMO, has delayed release in order to release 5.1. Notice I said "hopefully."
    03-27-2015 01:18 PM
  10. SpookDroid's Avatar
    03-27-2015 02:21 PM
  11. akpmehta's Avatar
    It requires restart after uninstalling fit to resolve the problem.
    03-31-2015 11:08 PM
  12. icecoolfsu's Avatar
    Yea. I'm having the same issue!
    04-01-2015 01:22 AM
  13. Adrian Ramirez's Avatar
    You don't have to uninstall fit, just turn off the activity detection in settings, then restart the phone.
    04-14-2015 11:23 PM
  1. go away lollipop
    By saradha devi in forum Android 5.0 Lollipop
    Last Post: 03-28-2015, 03:01 PM
  2. Replies: 1
    Last Post: 03-27-2015, 05:47 PM
  3. Replies: 1
    Last Post: 03-26-2015, 11:39 PM
  4. Replies: 2
    Last Post: 03-26-2015, 07:24 PM
  5. Why can't I send MMS on unlocked S4 mini?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 03-26-2015, 06:51 PM
