1. bassplayrguy's Avatar
    Most people are reporting better battery life after updating. Mine seems to be worse. I've master reset and cleared cache. Any ideas?
    Attached Thumbnails Worse battery life-1427476861787.jpg   Worse battery life-1427476872230.jpg
    03-27-2015 01:21 PM
  2. itguyjax8430's Avatar
    Master reset usually fixed the issue for most people. Did you just do it recently? Could be the ROM is settling and you could see it improve slowing over a few days.
    bassplayrguy likes this.
    03-27-2015 01:30 PM
  3. bassplayrguy's Avatar
    Yes. I wasn't getting great life after the update so last night I did a master reset. I will give it a week to see if it improves. I don't like the new battery screen.
    03-27-2015 01:44 PM
  4. itguyjax8430's Avatar
    Seems like they spend a lot more time trying to make it look pretty vs. trying to make it update better.
    03-27-2015 01:46 PM
  5. bassplayrguy's Avatar
    I just don't like that it doesn't tell you how long you have been using the current charge, only how much estimated time is left. On a positive note, the fast charging still works.
    03-27-2015 01:50 PM
  1. Problem with battery life and screen coming on
    By pjo1966 in forum LG G Watch
    Last Post: 05-07-2015, 05:22 AM
  2. Wear Kills My Phone Battery
    By FSchmitthammer in forum Android Wear / Wear OS
    Last Post: 04-13-2015, 03:22 PM
  3. Battery Pack
    By evyatarma78 in forum Ask a Question
    Last Post: 04-03-2015, 01:43 AM
  4. Battery charging intermittent
    Last Post: 03-26-2015, 04:32 PM
  5. Moto X2 Running Hot w/ Rapid Battery Drain
    By KawaiiKristi in forum Ask a Question
    Last Post: 03-26-2015, 01:06 PM
