1. Rmbrown1964's Avatar
    Is there a way I can change my text tones for each of my kids? I know I can change each ring tone. Yes I'm using the default text message app.
    And I have the Samsung Note 4. Thanks for your help.
    03-27-2015 03:25 PM
  2. Rukbat's Avatar
    I don't think you can with the stock app (or most SMS apps), but someone might have written one that can. It's certainly not impossible to write one that would do it.
    03-27-2015 03:30 PM
  3. Rmbrown1964's Avatar
    Thank you, I was using the Google messaging app, and it does let you change each text tone but it wasn't always sending my messages.
    03-27-2015 03:35 PM
  4. MrWinner77's Avatar
    You sure can.
    Open the contact you want
    Click Edit (button beside the star at the top)
    Then scroll to the bottom.
    Click add another field, then choose message tone.
    Once that field is added, select the tone you want
    Kjthomas0724 likes this.
    03-27-2015 03:38 PM
  5. Rmbrown1964's Avatar
    You sure can.
    Thank you so much!!
    03-27-2015 05:58 PM
  1. How can I get my Galaxy S5 out of boot recovery mode?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 12-17-2016, 04:01 AM
  2. HELP gear s not ringing
    By Therealm80 in forum Samsung Gear S
    Last Post: 07-13-2016, 09:18 AM
  3. How do I get rid of this loud screeching noise on my Nexus 4?
    By AC Question in forum Google Nexus 4
    Last Post: 03-27-2015, 03:36 PM
  4. How do I get rid of this loud screeching noise on my Nexus 4?
    Last Post: 03-27-2015, 01:20 PM
