1. Rmbrown1964's Avatar
    I have a Samsung Note 4 I'm using the stock message App. What is the best way to send multiple pictures. I can only attach 2 maybe 3 at one time. Thanks for your help.
    03-27-2015 03:30 PM
  2. itguyjax8430's Avatar
    Do you go in to the messaging app to send them or do you go in to Gallery and select the ones you want to send and send them that way?
    03-27-2015 03:36 PM
  3. Rmbrown1964's Avatar
    I go thru the text app. But let me try that. Thanks I will report back thanks
    03-27-2015 03:44 PM
  4. itguyjax8430's Avatar
    No Problem let me know.
    03-27-2015 03:45 PM
  5. z06mike's Avatar
    The problem, unfortunately, is a carrier limit on MMS. I really wish they would do away with the annoying MMS crap and just let us send pics and vids using data!!! Which carrier are you on?
    03-27-2015 05:58 PM
  6. Rmbrown1964's Avatar
    I agree
    03-27-2015 05:59 PM
  7. itguyjax8430's Avatar
    I agree
    If you root the phone you can use Wanam Xposed to modify the MMS limit.
    03-27-2015 06:14 PM
  8. anon67808's Avatar
    AT&T = locked bootloader w/ no root in sight and even if there was root for 4.4.4, AT&T's devious ways of automatically downloading and installing 5.0.1 will cancel that root right out.
    *Edit*
    I keep forgetting this isn't only an AT&T Note 4 message board so OP may have another carrier. Please disregard.
    03-27-2015 06:24 PM
  9. itguyjax8430's Avatar
    *Edit*
    Yeah I didn't even think about the whole AT&T thing. I have T-Mobile and I am rooted running a custom Stock Rom with Wanam installed.
    03-27-2015 06:30 PM
  10. Rmbrown1964's Avatar
    Thank for all your input.
    03-28-2015 01:26 AM
  11. sayzero0's Avatar
    What is the "MMS" crap that you are talking about? I still can't send any pictures through this stupid device.....
    05-14-2015 12:23 PM
  12. z06mike's Avatar
    If you can't send any pics at all I wound contact your carrier. There is probably a setting that needs to be adjusted on your account.
    05-19-2015 12:45 AM
  1. How can I get my Galaxy S5 out of boot recovery mode?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 12-17-2016, 04:01 AM
  2. HELP gear s not ringing
    By Therealm80 in forum Samsung Gear S
    Last Post: 07-13-2016, 09:18 AM
  3. Need help.
    By Rmbrown1964 in forum Samsung Galaxy Note 4
    Last Post: 03-27-2015, 05:58 PM
  4. How can I recall deleted texts with my Galaxy S5?
    Last Post: 03-27-2015, 05:07 PM
  5. How do I get rid of this loud screeching noise on my Nexus 4?
    By AC Question in forum Google Nexus 4
    Last Post: 03-27-2015, 03:36 PM
