1. Yathani's Avatar
    For some reason, I can't activate android device manager under administration when i want to turn the "allow remote Lock and erase".
    I have N910C running the second Poland lollipop release.
    Any info is greatly appreciated.
    03-30-2015 02:11 PM
  2. B. Diddy's Avatar
    Are you saying that you go to Settings>Security>Device Administrators​, try to check Android Device Manager, but aren't allowed to do so?
    Yathani and edzhusrolavs like this.
    03-30-2015 07:37 PM
  3. Yathani's Avatar
    Pretty much what you said. It's there however when i click to activate it just goes back to the previous screen unchecked.
    03-31-2015 01:52 AM
  4. B. Diddy's Avatar
    Are any other Device Administrators listed and checked?
    Yathani likes this.
    03-31-2015 01:53 AM
  5. Yathani's Avatar
    Yes,
    My email exchange which i removed because i thought it's the one causing the issue but that didnt help.
    For now what i have are
    - Tasker
    - Greenify
    - android device manager
    03-31-2015 02:43 AM
  6. B. Diddy's Avatar
    Just for the heck of it, uncheck them, and see if the problem persists.
    Yathani likes this.
    03-31-2015 09:30 AM
  7. Yathani's Avatar
    That didn't help unfortunately. I unchecked all and restarted the phone too!
    I'm thinking it might has to do with the second lollipop firmware
    04-01-2015 07:45 AM
  8. B. Diddy's Avatar
    Hmm, see what happens if you go to Settings>Security​ and tap Clear Credentials.
    Yathani likes this.
    04-01-2015 10:15 AM
  9. Yathani's Avatar
    Clear Credentials is grayed out can't click it. I did reboot into safe mod as well but still no luck.
    I think i will factory reset and see what happen.
    04-01-2015 02:52 PM
  10. B. Diddy's Avatar
    That sounds like the logical next step. Hope it works!
    Yathani likes this.
    04-01-2015 03:15 PM
  11. edzhusrolavs's Avatar
    Hello, I am having the same problem on my Samsung Galaxy s4. I really need to enable it, but it wont. And i dont want to do my phone reset, because i will lose all my data and games. please help!
    Sorry for my bad english..
    Thanks
    09-23-2015 09:11 AM
  1. Smart remote app
    By tat21985 in forum Samsung Galaxy Note Edge
    Last Post: 07-01-2015, 12:35 PM
  2. Replies: 69
    Last Post: 06-28-2015, 07:32 AM
  3. Verizon will be getting gold s6 and s6 edge!!!
    By AspenQn in forum Samsung Galaxy S6
    Last Post: 03-30-2015, 07:56 PM
  4. Replies: 1
    Last Post: 03-30-2015, 01:37 PM
  5. Replies: 2
    Last Post: 03-30-2015, 01:32 PM
