1. icecoolfsu's Avatar
    I'm having serious battery issues after the Lollipop update on my AT&T Note 4. I'm averaging 10 hours. Before the update I could go 1 day+. Today, while resting the phone on a pile of laundry I noticed the heart beat sensor would go on and stay on if some of the clothes got too close. It also now comes on whenever touched with my finger, even when screen is off. Is it doing this in my pocket too? Anyone else having this issue. I'm regretting the update. The light stays on (see pic) until you move the object away from the sensor.
    Attached Thumbnails Note 4 after AT&T Lollipop Update Issues-1427779485221.jpg
    03-31-2015 12:26 AM
  2. catberryday's Avatar
    Same here with the battery issue. I hate this update too. The thing that seemed to really help my battery was checking why my WiFi was showing up as on on the battery screen. I discovered under settings> connections> WiFi> menu> advanced that the box was checked for allowing Google services and apps to scan for WiFi even if WiFi was off. I unchecked it and the battery seemed to stablize.
    I was having an overheating issue and shutting off the phone and removing sim card stopped that.
    I wish I knew how to help you with sensor issue but I have never used mine and haven't had that issue.
    mty msi likes this.
    03-31-2015 03:12 AM
  3. NinJoeAssassin's Avatar
    Quote Originally Posted by sparksd View Post
    To wipe the cache partition, follow these steps:
    1.Turn the device off.
    2.Press and hold the following three buttons at the same time:
    •Volume Up key
    •Home key
    •Power key.
    3.When the phone vibrates, release the Power and Home key but continue to press and hold the Volume Up key.
    4.Continue holding the Volume Up key until the Android System Recovery menu displays and then release. This step may take several seconds.
    5.Press the Volume Down key to highlight 'wipe cache partition.'
    6.Press the Power key to select.
    7.When the wipe cache partition is complete, 'Reboot system now' is highlighted.
    8.Press the Power key to restart the device.
    After doing this my battery appears to be back to normal.
    03-31-2015 03:19 AM
  4. Realist86's Avatar
    I had the same issue with the heart sensor, once I set up S Health it was fine. I don't know why it would do that prior however.
    03-31-2015 08:24 AM
  5. mty msi's Avatar
    I'm thinking the only benefit for the phone to be scanning for Wi-Fi when it's off is possibly location services which cell towers should work just fine. Other than that I see no reason for it especially if you don't use any Wi-Fi network but your own home one which is my circumstance.
    03-31-2015 10:08 AM
  1. Lollipop bug, charging S L O W ! GPS still sucks.
    By dgcamero in forum Verizon LG G2
    Last Post: 06-01-2015, 10:21 AM
  2. How do I transfer all data from one Note 4 to another new one?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-31-2015, 06:50 PM
  3. Verizon S5 on Lollipop BOC4
    By GPilot750 in forum Samsung Galaxy S5
    Last Post: 03-31-2015, 02:10 PM
  4. Replies: 2
    Last Post: 03-31-2015, 07:28 AM
  5. Replies: 1
    Last Post: 03-30-2015, 11:59 PM
