1. BitingPanda's Avatar
    I wasn't paying attention, and I've somehow set my photo attachments to select from my Google photos cloud only. Often this means, the photo I want to share is not in the album to pull from, as I prefer that my photo backup only happens when charging/and attached to wi-fi.
    How do I clear this setting so that all photo attachments are selected from my device Gallery?
    Thanks!!
    03-31-2015 10:13 AM
  2. LeoRex's Avatar
    Go to Settings-Apps... The 'Photos' app might not be listed, as it really is just a sub-function of Google+... so click on Google+ is there's no Photos app. Click "Clear Defaults" under 'Launch by Default'.
    If all else fails, click on the three-dot menu under Settings-Apps and select "reset app preferences"... but that resets the chooser prefs for ALL apps... and its basically a last resort since you'll have to answer all those prompts for all the other apps.
    BitingPanda likes this.
    03-31-2015 10:24 AM
  3. BitingPanda's Avatar
    You are my hero!!
    Thank you so much.
    LeoRex likes this.
    03-31-2015 10:40 AM
  1. Replies: 5
    Last Post: 04-02-2015, 01:47 AM
  2. Gold Galaxy S6 and S6 Edge for Verizon
    By FrankSupreme in forum Samsung Galaxy S6 edge
    Last Post: 04-01-2015, 07:49 AM
  3. Replies: 3
    Last Post: 03-31-2015, 12:41 PM
  4. Can I get some help with some head phone problems?
    Last Post: 03-31-2015, 11:43 AM
