1. AC Question's Avatar
    I had to unmount my micro sd card in order to install an app. Now when I try to mount it it says it is damaged. it works fine when I plug it into my computer. I have the galaxy note 4. please help!!
    03-31-2015 03:27 PM
  2. monsieurms's Avatar
    That's odd...
    -First try. Insert card. Reboot phone. Does it work?
    ---Uninstall the app. Reboot the phone. Does it work? I don't know why you have to take out a card to install an app, but it sounds like the app does something to cards, so maybe that is the problem.
    --If that doesn't work, alas, I'd be inclined to format it in the phone. Hopefully, you have nothing irreplaceable, but you can always offload it first since you say it is working in the computer.
    03-31-2015 03:38 PM
  3. SpookDroid's Avatar
    You might just have to re-format it. Try backing up the card's contents in the PC, re-formatting the card in your phone, and see if that helps. Or you could format the card on your computer as long as you're using either FAT32 or ExFAT formats.
    03-31-2015 03:38 PM
  1. How do I add an .mp3 to a Link2sd card after partitioning?
    By jjmacey in forum General Help and How To
    Last Post: 06-05-2015, 07:06 AM
  2. How to switch from ptp to mpt with a broken screen?
    Last Post: 03-31-2015, 11:53 PM
  3. How do I delete a web page in Samsung Galaxy S5?
    By BettyMenzies in forum Samsung Galaxy S5
    Last Post: 03-31-2015, 07:16 PM
  4. Probably Led to the M7/M8/M9 problems
    By Gruff35 in forum HTC One M9
    Last Post: 03-31-2015, 06:17 PM
  5. Replies: 1
    Last Post: 03-31-2015, 05:53 PM
