anon(113926)
Active member
So my update finished and now the icons for all apps that are on my sd card are just an android badge with "sd" noted. Hmmm.... Restarted and nothing changed.
Me Too!
Me Too!
Me too! My Note 4 is running so awesome on 4.4.4 that I just don't need any aggravation from the update. So appreciate everyone chiming in on how it is for them!I'm going to wait. Hear how it is from you guys before updating. Thanks for letting everyone know that it's available.
I'm curious about the SD card as well. My old SD card gave my Note 4 a lot of Indexing problems when I first got it. I am sure it was the files on it, but nevertheless......I took the card out and never put in another. If no problems with using one with the update, I will buy a new 64 gb.1. Is foxfi confirmed to work still?
2. We have complete SD card access now right?
Not OTA. You will have to connect it to the pc and install the update utilityI'm using a Verizon one on simple mobile. Will I get the update?
How do I do that. Thanks.Not OTA. You will have to connect it to the pc and install the update utility
Sent from my Samsung Galaxy Tab Pro 8.4
