1. wetermommy's Avatar
    Since lollipop update has anyone else has clarity issues while I'll the phone? On my end the clarity is not good as there sounds like there is static and callers complain that my voice is "garbled" no one has ever complained since my phone updated overnight. Will a factory reset help the issue?
    04-03-2015 02:32 PM
  2. skatergirl's Avatar
    Are you Verizon? If so, have you activated the Advanced calling?
    04-03-2015 03:05 PM
  3. min_is_3's Avatar
    Is there an extra charge for advanced calling?
    Sent from my Galaxy Note 4
    04-03-2015 03:15 PM
  4. clownin72's Avatar
    No extra charge
    04-03-2015 03:18 PM
  5. ClaudiaP's Avatar
    It only works if the other person you are talking to also has Verizon and advanced calling.
    04-03-2015 03:23 PM
  6. min_is_3's Avatar
    OK thanks
    04-03-2015 03:24 PM
  7. wetermommy's Avatar
    No I'm with att
    04-03-2015 03:27 PM
  8. skatergirl's Avatar
    No I'm with att
    Does AT&T have HD calling?
    04-03-2015 07:31 PM
  9. fragologist's Avatar
    Does verizon advanced calling use up my capped 4g data?
    I am in the process of making my Note 4 self aware.
    04-03-2015 07:55 PM
  10. Bbeelzebub's Avatar
    No. It only uses data for the video portion of you are doing an Advance Calling Video call. Audio doesn't count against your cap in either a basic voice call or in a video call.
    fragologist likes this.
    04-03-2015 07:59 PM
  11. fragologist's Avatar
    Can you do a video call via wifi?
    04-03-2015 08:28 PM
  12. Bbeelzebub's Avatar
    Yes, but the call needs to be initiated on 4G and then it will automatically be handed off to your WiFi network. (Got that from the Verizon site.)
    You can also do 6 way calls on advanced calling. This will revolutionize phone s*x. LOL
    04-03-2015 11:16 PM
  1. Lollipop Lock Screen Addiitional Information Greyed Out
    By jedi44 in forum Samsung Galaxy S4
    Last Post: 07-29-2015, 01:59 PM
  2. Lollipop
    By Sphinx5779 in forum Samsung Galaxy Tab S 10.5
    Last Post: 05-15-2015, 08:47 PM
  3. Try this for the high Cell Standby drain issue
    By erasat in forum Samsung Galaxy S6
    Last Post: 05-01-2015, 07:47 PM
  4. Replies: 4
    Last Post: 04-14-2015, 06:48 PM
  5. Replies: 3
    Last Post: 04-04-2015, 03:12 AM
