1. AC Question's Avatar
    I charge my phone while i sleep and is left turned on. I went to bed around 5% and woke up 7 hours later and the phone was still charging at 75%. Something is clearly not right here. Does anyone know? This phone is relatively new i got it a week ago and this problem started happening 2 nights ago (happened both nights in a row now)
    04-03-2015 02:37 PM
  2. belodion's Avatar
    Welcome to Android Central.
    It may be a fault with the USB lead or USB port, or damage to either of those. It could be other things, but check those first, or have them checked.
    Also, routinely discharging heavily before recharging will shorten the life of the battery. It's best to recharge at about 40%. Read this guide by Rukbat:
    http://forums.androidcentral.com/amb...batteries.html
    04-03-2015 03:51 PM
  3. Rukbat's Avatar
    It could also be that you're leaving the phone on during charging, and the phone is using so much current (some rogue app, some app running that shouldn't be, weak cell signal - which costs battery) that there's very little current coming from the charger that's left for actually charging the battery. (Charge = current in from the charger minus current used by the phone.) There have been many posts here where the amount of current used by the phone is so large that the battery discharges while the charger is plugged in.
    04-03-2015 04:09 PM
  1. Replies: 75
    Last Post: 04-06-2015, 09:50 AM
  2. Replies: 1
    Last Post: 04-03-2015, 04:54 PM
  3. Replies: 1
    Last Post: 04-03-2015, 04:46 PM
  4. Replies: 2
    Last Post: 04-03-2015, 02:00 PM
  5. how do I change owner when buying a used tablet?
    Last Post: 04-03-2015, 01:39 PM
