04-28-2015 12:50 PM
226 ... 34567 ...
tools
  1. bharding08's Avatar
    battery life has been terrible with lollipop.
    Philip600rr and cnotes63 like this.
    04-06-2015 07:33 PM
  2. dsignori's Avatar
    Interesting. I don't find this to be the case at all on mine with the update. . Auto brightness is fine.
    04-06-2015 07:38 PM
  3. Philip600rr's Avatar
    I did a factory reset and all is well.... Battery life isn't the best. I'm @ 52% by the end of the day instead of 70%.
    04-06-2015 07:50 PM
  4. Android D's Avatar
    I don't know if this is a bug or just something that bugs me but why doesn't anything happen when I click on the lockscreen notifications?
    hmm..It takes me to the app whose notification is present on the lock screen..It's funny though I though swiping it away would take me to the app, atleast swiping it to the right!
    oh well..
    04-06-2015 10:37 PM
  5. kirksucks's Avatar
    oh well..
    Tapping it seems to highlight it. When I swipe the screen to unlock it unlocks to that app.
    04-06-2015 10:40 PM
  6. Android D's Avatar
    i click on the app and it takes me directly to that app..lol
    jimd1050 likes this.
    04-07-2015 12:04 AM
  7. Adawg1203's Avatar
    Auto brightness does not work as well as it use to. It doesnt go as dim in darker rooms and always seems to be a bit too bright for any given situation.
    I don't think this is new. Auto brightness never dimmed enough in dark places for me. What I do in a dark environment is turn the auto brightness off and set the screen brightness to its lowest setting and that does the trick.
    04-07-2015 03:31 AM
  8. Dankees's Avatar
    How come my back button and menu buttons don't illuminate or work?
    And, where's my 4G?
    04-07-2015 06:07 AM
  9. ansa82's Avatar
    I can no longer access the "Sound and notification", when I try I get the following error " Unfortunately, Settings has stopped". Very annoying. I had selected to hide sensitive info; but cannot get back in to make any modifications.
    Has anyone else seen this problem after upgrading?
    I have the exact same problem. I cleared cache but it didn't fix anything. I'm hoping there is a fix eventually.
    04-07-2015 07:17 AM
  10. fofjjsr's Avatar
    how is this different from using 4G to send MMS? Somehow our phones were able to switch back and forth when needed.
    VOLTE functions different than MMS. I would have to look up the details again but I know the towers had to be reprogrammed and activated for VOLTE. All the phones Verizon carries that have VOLTE enabled do the same thing.
    04-07-2015 08:38 AM
  11. goin_nil's Avatar
    I've stopped using Auto Brightness years ago when I find the Display Brightness app.
    https://play.google.com/store/apps/d...playBrightness
    You can very quickly and easily change the brightness just by sliding your finger on the screen no matter what app you are using (game, movie, video, etc) without exiting the app or going to settings or pulling down the notification bar.
    It even has negative brightness for when you are in a really dark room and don't want your screen to blind you.
    04-07-2015 09:12 AM
  12. sforsyth01's Avatar
    Have you done a factory reset? I was having the same issues with battery and a reset seems to have made it better. Still a little worse than kitkat but I believe that to be the fact that it is constantly connected to 4G for advanced calling.
    04-07-2015 11:26 AM
  13. Nakrohtap's Avatar
    Is it possible that you have sounds on your SD card that maybe causing this? Maybe a sound was set as a ring tone or notification that is no longer there?
    Sent from my SM-N910V using Tapatalk
    04-07-2015 12:11 PM
  14. kirksucks's Avatar
    Then if I tap it I see the second pic. "swipe to unlock" if I swipe it takes me to the text or whatever.
    Attached Thumbnails Verizon Lollipop Problems anyone?-1428427183518.jpg   Verizon Lollipop Problems anyone?-1428427224875.jpg
    04-07-2015 12:21 PM
  15. SamSamsung11's Avatar
    I don't wanna make a new thread for this but I am having a weird problem after the update. Usually in the texting app at midnight it will indicate that the date has changed. So for example at exactly 12 am it will insert a date stamp in the convo. Since the update it changes the date stamp at 1am for the last two nights. Has anyone else experienced this? It's really not a big deal but still kind of annoying that the date stamp gets changed at 1am instead of midnight like it should and always would before the update. Thanks for any help.
    04-07-2015 01:57 PM
  16. ronpfid's Avatar
    Note 4 Verizon 5.01
    Just noticed, I can't listen to a visual voicemail unless I put it on speaker. If I try to hold the phone to my ear, my ear or something triggers it back to a lock screen. THAT is really annoying. Didn't the morons in development even try to listen to a voicemail and notice this?
    Anyone else on Verizon with visual voicemail notice this? From the main vm screen, you can see the speech to text version of the vm, if you hit the triangle play button as, soon as you put the phone to your ear, poof back to lock screen. If you have visual vm, try it
    04-07-2015 02:11 PM
  17. yeatzee's Avatar
    2 major issues for me that are very frustrating.
    1) YouTube is laggy, longer videos frequently stop or stutter with the frames sticking and audio cutting in and out when this happens. I tried "uninstalling" YouTube but no dice.
    2) Bluetooth playback also randomly stops or stutters.
    Other then that it's been okay, I can't say I actually like the update I liked my phone better with kitkat but such is life. The two issues above are huge to me due to the amount of media consumption I do so if anyone has a fix let me know
    04-07-2015 02:12 PM
  18. clownin72's Avatar
    I noticed the you tube problem last night as well. Even a short video froze on me. I had to go back and start again. Next time it played all the way through
    04-07-2015 02:33 PM
  19. jimd1050's Avatar
    I just tried it on my phone Ron... it works fine. The screen does not lock and I am able to listen to the message on the handset without speaker selected???
    04-07-2015 02:39 PM
  20. ronpfid's Avatar
    thanks for trying, really weird it does that to me, as soon as my ear touches the screen the sound stops, I look, it's at the lock screen.
    Thanks much!
    04-07-2015 03:02 PM
  21. blaidan's Avatar
    2 issues thus far:
    1) Constantly getting a popup message that com.sec.imsservice had stopped (like every 5 seconds). Fixed this by going into the Application Manager and then going into BOTH Contacts and com.sec.imsservice and clearing the cache (I booted into Safe Mode first just so I wouldn't have to deal with the constant popups and then rebooted the phone after clearing both caches).
    2) Youmail application opens but voice mail no longer goes to Youmail (defaults to Verizon vmail app now) and I cannot make it use Youmail again. Haven't figured out how to get this working. Anyone else having this Youmail issue?
    04-07-2015 03:12 PM
  22. Old Guy 59's Avatar
    I had the com.sec.imsservice issue and despite doing what you did...repeatedly....never got the error message to go away. Had to do a factory reset. Afterwards YouMail works fine....although you do have to go back into YouMail and re-setup the VM forwarding. Good Luck!
    04-07-2015 04:38 PM
  23. ClaudiaP's Avatar
    A lot of people have had that issue and it seems the only way to fix it is to do a factory reset. I did the reset and everything is working fine now.
    It is a little time consuming but most of that is reentering passwords for apps, I didn't lose anythings between either a Samsung cloud backup or Verizon cloud backup. I don't remember which one it was but I was asked if I wanted to do that during the reset process and I said yes, that part restored my emails and IM's. I use Firefox browser so I've not had to redo passwords for any of my sites because Firefox sync takes care of all of that.
    I am noticing a big improvement in battery life since the reset and the phone seems snappier overall.
    rrabago and Old Guy 59 like this.
    04-07-2015 05:26 PM
  24. rrabago's Avatar
    I can second that, after several days of sluggish behavior l decided to do a factory reset. Better results all around... I'm very happy with Lollipop at this point.
    All the best!
    04-07-2015 05:38 PM
  25. Rmedy21's Avatar
    You can no longer take a picture while pressing the home button and the power button. When I try and do that it takes me to Google now page. I can only palm swipe.
    04-07-2015 07:14 PM
226 ... 34567 ...
  1. Lollipop Lock Screen Addiitional Information Greyed Out
    By jedi44 in forum Samsung Galaxy S4
    Last Post: 07-29-2015, 01:59 PM
  2. Replies: 4
    Last Post: 04-14-2015, 06:48 PM
  3. Replies: 5
    Last Post: 04-09-2015, 04:23 PM
  4. Replies: 3
    Last Post: 04-04-2015, 03:12 AM
  5. call issues with lollipop?
    By wetermommy in forum Samsung Galaxy Note 4
    Last Post: 04-03-2015, 11:16 PM
