Verizon Lollipop Problems anyone?
carraser891
424
3
I made sure i cleared cache and junk before downloading, now since the download Im having nothing but issues. First boot up the phone was ridiculously laggy, so much so that i did a hard reset. Tried doing that and the phone froze in the process. Had to pull the battery, and boot up again and it was stuck on the Verizon boot screen for about 5 minutes. then it went straight to the home screen (no lock screen) and the top bar was missing. A message saying "system not responding". Now on my second hard reset. What a nightmare...
skatergirl
Retired Moderator
Mar 22, 2011
3,233
96
48
So sorry you are having problems. So far so good for me. One new feature is not working so I need to troubleshoot. Besides that it's working out great.
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
Aren't you supposed to clear the cache AFTER the update? When I flashed ROMs on previous phones, it was always install ROM first, then clear cache and reboot.
Sent from my SM-N910V using Tapatalk
scribe4food
486
Working pretty good on my end. Cleared the cache after down load and installation, and have had no issues. Don't know if this is the placebo effect, but it seems more responsive -faster.
carraser891
424
3
Didn't think it would hurt to make sure everything was cleared beforehand...
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,278
23
You can try clearing the cache.. and if you want to take a drastic step you can restore factory settings then re-setup. That usually solves issues during a big upgrade.
Bayard Davis
4
The problem I have is when I get a notification, my phone won't light up saying I have a notification? Any help.
russel5150
1,274
6
Mine updated and i just did a factory reset so right now its updating apps. Then i have to get my contacts back lol.. should be n my gmail lol
rjr1209
66
3
Not having any issues but does anyone know if you can change that orange theme on stock messaging
MoonShade
58
Hang in there. Mine was frustrating for a while after updating. All good now. Just need to figure out how to remove some of these damn notifications.
SteelGator
1,220
5
Hangouts does not have that garish orange color. :p
As for notifications. I wish I could prevent apps from appearing on the home screen and notification bar separately.
Sophia Long
I'm having some major installation problems. I spent all afternoon speaking to Verizon and Samsung customer service on the phone and then ended up going to the Verizon store as well as the Samsung Experience center in Best Buy. All of the customer service reps were useless and clueless. I can't tell if it's a software or hardware issue.
So I went to system updates and saw that the update is available for my phone:
I downloaded the 1st one.
I tapped to install and then my phone does a recovery boot and after it's done rebooting I get this popup that says update was unsuccessful:
I factory reset my phone and the same thing keeps happening. I also tried updating via PC through VZW installer, Samsung Kies, and the Samsung service rep used their software as well. When plugged into computers it says my phone is already "up to date" with the 4.4.4.
Does anyone have any idea of what's going on or is anyone experiencing the same thing?
SteelGator
1,220
5
I would go to the download folder and delete the file, then wait a day and check for downloads again. Your install file may of corrupted during the download, so it cannot install. As a precaution, make sure you have a good wifi connection when you download again.
I'm sure others will have ideas as well.
htc evo 4g
330
5
WHen you mean "clear cache", do you mean by powering down and holding the 3 buttons at the same time then select wipe cache partition?.... Is it that route? thanks
cruiz1022
66
I had no problems with my update and since I've updated it. Thank God. The only little issue I had was with Google play services for the first few minutes after updating saying there was an "error"
beh
1,378
16
I downloaded it about 4 hours ago and installed it. It seemed to run fine. Following the suggestion of several folks I did a factory reset and then set it up again. Works great so far and no issues.
EDIT:
I have found that the lock screen has a feature that I don't like. Namely, when Notifications are active and a message or other event happens, the lock screen large clock (an option for the clock I use) and the "additional information line" (which I also very much like) change. Namely, the clock is made much smaller and moved from the center of the lock screen to the left side and the additional information is no longer seen.
After shutting off Notifications in Lollipop and then in every other app with a notification option, and in every email acct in my email app I mostly have gotten the lock screen to behave like the KitKat version.
All that being said, this is a minor personal issue and not a bug or defect in Lollipop in my opinion, simply a different method of operation.
anticlutch
65
Seems like I may be one of the few that are experiencing issues. Did a dirty OTA update to Lollipop and noticed that it was dropping frames and stuttering, particularly with a live wallpaper (phase beam and bubbles). Tried to clear the cache via recovery mode and didn't see any difference so did two wipes consecutively (also via recovery mode) and set everything up as before. Still dropping frames and stuttering simply by swiping between my homescreens (with the live wallpaper in the background). This along with the bad color choices (garish orange, lots of white everywhere) and changes to the lockscreen (music control buttons are tiny now!) cements my opinion of Lollipop across 4 devices (Nexus 7 2013, LG G2, HTC M8, Note 4) as being nothing but utterly disappointing. I'll most likely be trying to find a way to roll back to Kit Kat, at least for the foreseeable future.
Edit: Just wanted to add that while I did noticed the phone was warm, it was not unusually so. I never noticed there being any dropped frames on Kit Kat when it was running even hotter (~105F), so it's probably not due to throttling. There also still seems to be a bit of a hesitation after pressing the recent apps button. Perhaps these will be addressed in a future update but as for now, if you absolutely do not need to have Lollipop, I'd advise to stay on Kit Kat for as long as possible. You'll have root, less issues, and pretty much the same UI.
nayminthuyain888
