jimd1050
Champion
"Settings">"Device">"Sound and Notification">scroll down to "While Locked" and click - you then have a choice of "Show all content", "Hide sensitive content" or "Do not show notifications"!
How do we define "sensitive"? Video I saw on Lollipop showed it as part of the Sound and Notifications - Application Notifications page. But it is missing on the Note 4.
Sent from my GT-N8013 using Tapatalk
I gave up. Talked to both Verizon and Samsung. They said the only fix for "so is there a fix for the "sound and notification" force close issue" was to do a factory reset. So I used Kies to back up, did the factory reset and then did a restore.
"Hide sensitive content" doesn't show emails or texts that someone else could read with the phone locked - "Show all" does exactly that! And the setting IS part of Sound and Notifications - just scroll down to "While locked", click it and you'll see the 3 choices.
my guess is it needs a constant connection to the 4G network for advanced calling
So every phone that has advanced calling will show 4G even when connected to WiFi. It will show but be inactive. It is there so when you are on WiFi it will still make HD calls. Now if you have Advanced Calling off then it will just do nothing.
Hang in there. Mine was frustrating for a while after updating. All good now. Just need to figure out how to remove some of these damn notifications.
