The Verizon page said to expect battery drain for a couple of days. I have gone through two batteries today. I am not sweating it though. I wiped the cache partition and if it is still draining after a few days I will just do a factory reset.
I installed the update last night; on standby the battery is fine, but as soon as I turned the screen on and did anything the battery just dropped way off. Less than an hour of screen-on time and the battery dropped ~25%. So I just pulled the trigger on a reset. Everything is backed up, so no big deal. We'll see how it works going forward.
I just went ahead and did the factory reset. I figured just to get it over with.
How are things after the reset?
forgot how to wipe cache partion of just cache in the storage?
I agree on the "Standby" - I had it fully charged when I went to bed and it was at 98% when I got up. Never before - usually 88% - 90% after an overnight standby! The rest, too soon to tell - using it too much checking everything out!No change either way. Phone has been acting normal since the update. The standby may be better but it's too early to tell. I don't do factory resets on my devices and luckily they all have been fine.
And the phone is wonderful now?
