05-27-2015 03:48 PM
100 123 ...
tools
  1. skatergirl's Avatar
    The Verizon page said to expect battery drain for a couple of days. I have gone through two batteries today. I am not sweating it though. I wiped the cache partition and if it is still draining after a few days I will just do a factory reset.
    sanchez2005 likes this.
    04-03-2015 11:19 PM
  2. carraser891's Avatar
    The battery drained quick during the update (obviously) but after the battery was great. Took it off the charger with 60% at 7pm and its 2am and the battery is at 35%. Moderate usage
    skatergirl likes this.
    04-04-2015 02:06 AM
  3. clownin72's Avatar
    Yes mine is draining a little faster than before on kitkat, even just in standby. I'll give it a couple days and see but I got a feeling a factory reset will be in my near future.
    04-04-2015 08:55 AM
  4. spotnjack's Avatar
    I installed the update last night; on standby the battery is fine, but as soon as I turned the screen on and did anything the battery just dropped way off. Less than an hour of screen-on time and the battery dropped ~25%. So I just pulled the trigger on a reset. Everything is backed up, so no big deal. We'll see how it works going forward.
    04-04-2015 11:46 AM
  5. carlos12001's Avatar
    I just went ahead and did the factory reset. I figured just to get it over with.
    skatergirl and angryamygdala like this.
    04-04-2015 12:00 PM
  6. skatergirl's Avatar
    How are things after the reset?
    04-04-2015 12:11 PM
  7. skatergirl's Avatar
    And the phone is wonderful now?
    04-04-2015 12:11 PM
  8. spotnjack's Avatar
    I'm still setting the phone up, logging in to all my accounts, etc, so I'm murdering the battery right now. Still too soon to say.
    04-04-2015 12:27 PM
  9. Alex Wetzel's Avatar
    So far, it's a little worse than kitkat. But not terrible.
    sforsyth01 likes this.
    04-04-2015 12:33 PM
  10. mookiekillsit's Avatar
    Mine has improved. I wiped cache immediately after the upgrade but that's it.
    04-04-2015 12:44 PM
  11. russel5150's Avatar
    I can see a small difference in mine, so it will prob smooth out n a couple days.
    I did go ahead and do a factory reset after the updates, just to get it done on my day off
    04-04-2015 12:45 PM
  12. bulldogmoe7's Avatar
    forgot how to wipe cache partion of just cache in the storage?
    04-04-2015 01:23 PM
  13. fallenangel808's Avatar
    Factory reset is a pain but it does help especially after an update like lollipop. Just to see how my phone would be I did not do the factory reset and the battery was hot plus the drain was terrible, battery life went down by 20% w/in an hour. After the reset my phone seems way better and battery life has improved overall.
    04-04-2015 01:34 PM
  14. clownin72's Avatar
    I have noticed standby is decent but yes as soon as I get the screen on and using it quick drain
    04-04-2015 01:37 PM
  15. mookiekillsit's Avatar
    Cache partition. Turn off phone > power back on holding the power, volume up, and home key > wipe cache > reboot
    04-04-2015 01:43 PM
  16. Adawg1203's Avatar
    No change either way. Phone has been acting normal since the update. The standby may be better but it's too early to tell. I don't do factory resets on my devices and luckily they all have been fine.
    Tatt2014 likes this.
    04-04-2015 02:12 PM
  17. Huggie87's Avatar
    My battery seems to be fine so far
    04-04-2015 02:21 PM
  18. jimd1050's Avatar
    I agree on the "Standby" - I had it fully charged when I went to bed and it was at 98% when I got up. Never before - usually 88% - 90% after an overnight standby! The rest, too soon to tell - using it too much checking everything out!
    04-04-2015 03:07 PM
  19. pauldroidr2d2's Avatar
    My battery life has been horrible since the upgrade. I'm going to try wiping the cache before going the reset route.
    04-04-2015 03:14 PM
  20. carlos12001's Avatar
    Everyhing works perfectly, I think battery is even a little better, considering I've been hammering away on it all day.
    jimd1050 and Tatt2014 like this.
    04-04-2015 03:19 PM
  21. ansa82's Avatar
    Not yet. Update went smoothly and note 4 running great!
    Alex Wetzel, jimd1050 and Tatt2014 like this.
    04-04-2015 03:21 PM
  22. carlos12001's Avatar
    Just go ahead and reset it. May as well get it done. I did that on all my iPhones too whenever an update came. Too bad every update made them worse.
    04-04-2015 03:22 PM
  23. fofjjsr's Avatar
    My phone drained fast at first. Charged it over night and today it is running great.
    04-04-2015 03:53 PM
  24. Android D's Avatar
    I really hate how we now have the whole battery graph..and now it shows how long the battery will last instead of how much time it's been going for!! and how long it will last is inaccurate and depends on how u use ur phone!
    Anyway to revert back to the old format under the battery section?
    04-04-2015 03:57 PM
  25. jimd1050's Avatar
    I looked around quite a bit - I think unfortunately, "what we see is what we get"!
    04-04-2015 04:07 PM
100 123 ...
  1. One Lollipop issue - Nova swipe to expand notifications broken
    By jmk32 in forum Samsung Galaxy Note 4
    Last Post: 03-07-2016, 10:04 PM
  2. What's with "Verizon Wireless" top left on lock screen?
    By lagunarad in forum Samsung Galaxy Note 4
    Last Post: 04-04-2015, 09:09 AM
  3. Much less free space after update on Verizon Galaxy Note 4
    By MrMLK in forum Samsung Galaxy Note 4
    Last Post: 04-03-2015, 11:31 PM
  4. OTA Android 5.1 bricked my Nexus 5- any solutions?
    Last Post: 04-03-2015, 11:07 PM
