Turn off Facebook notifications in the app
Why does your phone's screen have to be on to use as an alarm clock?? I'm so confused by this..... the bigger problem might not be the notification......
So you can see what time it is if you roll over and wake for a second. With your logic, why does any alarm clock have to have a time in it. Nothing to confusing..
The bigger problem is It's a useless feature that interferes with what people want to use their phone for.
I found an app called Headsoff in the playstore that is supposed to help you turn off certain lockscreen notifications on lollipop. I don't know if it works or if it will help this situation because I haven't used the app. I read some of the reviews and they were good. Just offering a suggestion for those who don't like the new notification system.
Is this the app?
https://forums.androidcentral.com/e...ails?id=com.jamworks.noheadsup&token=xzhPQMfE
I have haven't researched the developer or gone through the reviews. One of the first three reviews did say it doesn't require root.
Thank you for posting something trying to give a solution.Yes. That's it. No it doesn't require root.
Has anyone tried this and if so how did you set it up to not get the battery full notification.
Again, this whole discussion is over a useless notification that Samsung or Google thought was great. I don't even care if the notification pops up, but at least have it time out in 10 seconds. I really don't think my reasons for wanting the screen on is relevant, it's the useless notification.
Is this the app?
https://forums.androidcentral.com/e...ails?id=com.jamworks.noheadsup&token=yf7QnU5t
