1. bamf-hacker's Avatar
    I have a Sprint Note 4 that I just had unlocked, but I want to get rid of all of the Sprint boot screens and auto installed Sprint apps. I am a new Android user and have updated the Note 4 to 5.0.
    I have Keis installed on my PC.
    Any advice would be awesome!
    Thanks
    04-07-2015 09:27 AM
  2. aokusman's Avatar
    You need to root to do that.
    04-07-2015 09:31 AM
  3. bamf-hacker's Avatar
    Send some info my way
    04-07-2015 09:33 AM
  4. bassplayrguy's Avatar
    This is not possible by unlocking the phone. It has to be rooted and I would strongly advise against doing that.
    04-07-2015 09:36 AM
  5. bamf-hacker's Avatar
    So, With the phone unlocked I can still use it overseas and the dumb Sprint Spark splash logo and apps should not matter??? If that is the case I will just live with it, as long as I can use it with any carrier.
    04-07-2015 09:42 AM
  6. bassplayrguy's Avatar
    Unlocking a phone to use on other carriers doesn't give you access to what is needed to delete bloat apps or reprogram the basic functionality of the phone. That takes being rooted. Unless you are well versed in rooting and how to program and troubleshoot, I would not entertain the thought of rooting this device.
    bamf-hacker and aximtreo like this.
    04-07-2015 09:45 AM
  7. bamf-hacker's Avatar
    I am pretty solid and techy, but this is not a main device. I was going to use it as a hotspot overseas with a local carrier SIM. So I am not going to take the time to root and update the boot loader. I was checking to see if my Android peeps had a quick solution for me. I can live with the splash screen and bloat as long as it will work on other carriers
    Thanks for the help!
    04-07-2015 09:49 AM
  1. Why won't my Droid Turbo charge?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 11-22-2018, 06:02 PM
  2. Replies: 1
    Last Post: 04-09-2015, 01:19 AM
  3. Replies: 1
    Last Post: 04-07-2015, 09:38 AM
  4. Can I fix my bricked LG G2?
    By LeandroBR in forum LG G2
    Last Post: 04-07-2015, 09:31 AM
  5. Replies: 0
    Last Post: 04-07-2015, 09:05 AM
