1. sstephen17's Avatar
    I did a factory reset with the hopes of improving battery life. All of my apps seem to have re-installed correctly except for Google Fit. I couldn't find it so I went to Google Play. It says that my device is incompatible. I did not have this issue when I first downloaded Lollipop; only when I did the factory reset. I like the app so I'm wondering what the issue is.
    04-07-2015 06:53 PM
  2. Bbeelzebub's Avatar
    It will create issues with your heart rate sensor. It isn't available from Google Play I assume because of that.
    PookiePrancer likes this.
    04-07-2015 07:25 PM
  3. mikakat84's Avatar
    I use lollipop and google fit works fine on my phone.
    04-07-2015 10:02 PM
  4. Beninden's Avatar
    Same here. Note 4 on Lollipop. No Google fit. Play store says not compatible. What gives? This is a pretty big break.
    04-10-2015 04:16 PM
  5. fasnic's Avatar
    Same issue, but as others say they can use it... Curious if people who are getting that message are rooted?
    04-13-2015 01:13 PM
  6. sstephen17's Avatar
    I downloaded a Google Fit APK and installed it that way. Works fine now.
    04-13-2015 03:09 PM
  7. mikakat84's Avatar
    Yeah no root or anything..got lollipop update and google fit works fine.
    04-13-2015 04:16 PM
  8. PookiePrancer's Avatar
    I'm not rooted, and it doesn't come up for me. Probably Samsung's way of forcing people into their apps.
    Actually, Bbeelzebub is probably correct.
    04-14-2015 12:08 PM
  9. Aurelio Herranz's Avatar
    Can you post a link to download the apk? Or
    Thanks
    04-16-2015 07:32 AM
  10. sstephen17's Avatar
    04-16-2015 07:26 PM
  11. b00ky's Avatar
    I saw the incompatible message just now too.
    I think the issue is today some of us had Fit installed prior to the update and it remained after the update. However, I was troubleshooting severe battery drain from Android Systemand some posts mentioned Fit, which made sense since my heart rate sensor was coming on all the time.
    So, I uninstalled Fit after having lollipop.
    Then I downloaded some new apps that tie on to Fit which prompted me to download Fit.
    That's when I saw the incompatible message.
    I'm assuming Google is working on a fix our waiting for Samsung to update (yeah right).
    Fyi...battery still seems bad (worse than kit Kat) without Fit installed.
    04-16-2015 08:28 PM
  1. Why can't I use Google services after I reset my device to factory settings?
    By AC Question in forum Samsung Galaxy Note 10.1
    Last Post: 04-11-2015, 01:01 AM
  2. Replies: 1
    Last Post: 04-08-2015, 02:27 AM
  3. Replies: 1
    Last Post: 04-08-2015, 02:22 AM
  4. Replies: 1
    Last Post: 04-08-2015, 02:04 AM
  5. Much improved battery life since hard reset after lolipop update.
    By soldier45 in forum Samsung Galaxy Note 4
    Last Post: 04-07-2015, 09:06 PM
