Android D
But it's funny though I have never had this issue while on Kitkat with the same messenger app...I don't think i have ever updated that app until it forces me to do so!
Just downloaded Lollipop 3 days ago on Koodo/Telus. It's the worst OS I've ever encountered and I use to be a big blackberry guy. The notifications on the lock screen are HORRIBLE just down right disgusting. No matter what I'm doing on my phone on YouTube, watching a movie, playing Clash of Clans and I get a Twitter notification it fills up 1/4 of my screen instead of just the status bar on 4.4.4. And sometimes it stays for 3 seconds, sometimes 5 and sometimes .3 seconds. The text msging is horrible and might as well just use hangouts because it's the same layout. And the Orange! Why Orange??!! I'm gona cry. Why would someone release this POS operating system. And the notification pull down panel is depressing : ( such big bubbles and take up such room for no reason. And when you go to clear it takes longer for them to clear now cuz google wanted make it look cool with a card like closing technique. I'm considering an iPhone 6+. N since I waited like 6 months to download lollipop I don't see any changes coming in 2015
Hmmmm...tht's interesting.
So you are saying in the Past the Youtube app used a lot of Data for you? How did you fix it?
So do you think perhaps this issue is app specific? like I was using the FB messenger app to make that call, was on the call for 40 mins, and then my data usage went up..do you think it's just the messenger app then?
To answer the first question, I typically shut off mobile data when I watch you tube what was happening for me is that my tablet was switching over to wireless data instead of staying on the very strong wifi signal in my house. That was easy to fix, because on my tablet I just switched off mobile data and left it. But the same thing happened on my phone, too. I am Not exactly certain what triggers that behavior, but I was able to prove it sufficiently enough that Verizon gave me credit on two separate bills for data overage. and just in case, I limit my mobile data on the phone and on the tablet so I use on this account to make sure that I don't go over.
. on the other question of whether I think it was facebook Messenger eating your data, I truly cannot say but it sure does sound a likely suspect...
What I can say though is that since the lollipop update that I did, nearly every program that I have has had an update from the App Store. and what that means is these apps have been changing to accommodate lollipop, or for whatever other reasons there are.
Everyone seems quick to blame lollipop because that makes the most sense, however the fact that these problems seem intermittent and don't affect all users would seem to indicate app specific problems not operating system specific problems...
I let Lollipop install on my Nexus 7, hated it, and went through the hassle to get back to KitKat. I'm now ignoring the Lollipop update notification on my Tab S, which is what I plan to do when the update hits my GN4.
I'm wondering if there has ever been a prior version of Android that elicited so many "This version sucks!" reactions.
I have a note EDGE and the Lollipop totally destroyed the way my phone showed notifications they used to show up on the EDGE screen now they pop up on the main screen and no longer on the EDGE the phone constantly runs very hot right where the SD card is ... The phone lags slower than my grandmother crossing the street and it drains my battery so fast its crazy everything is affected in a negative way my wifi is a mess i have to turn it off then back on when I get home several times just to get internet access and I have reset my router and the phone several times when notifications pop up on the top of the screen if i click on them nothing happens I have to go an open the app to be able to read the notification... I have done all but factory reset the phone I want KK back like yesterday... This is a flop of all flops on googles part
My best friend is EXTREMELY angry at the Galaxy Note 4 right now and it has to do with Lollipop. His phone constantly lags, keeps getting pop up messages saying that "Unfortunately, YouTube has stopped" or some other app saying the same kind of message, his phone has randomly restarted and now gets so hot that you can't really hold onto it. He has done every suggestion online that it says to do to fix these problems including factory reset and still encounters these problems. He's also got another friend he works with who had the Note 4 that was having those same issues, but he got rid of his.
Is Lollipop really causing that much headache on the Note 4? I've witnessed the stuff he was talking about and was quite shocked. I've got a Galaxy S6 and it runs lightning fast and I have not encountered the type of problems he has with Lollipop. I've heard it is a memory leak issue and that Google still has not fixed the issue even with some updates to try and fix the problem. Is this something I may eventually run into with my S6?
Lollipop kills this great phone!
Check my thread about it:
http://forums.androidcentral.com/sa...fe-back-my-note-4-i-didn-t-like-lollipop.html
My phone runs fine on Lollipop. I expect quite a few others do too.
It is unfortunate that many have had problems with it. When I upgraded my S5 I had quite a few problems with it but I managed to sort them all out in the end. My Note4 upgrade went seamlessly and I didn't even have to do a factory reset.
Posted via a kicking Note4 on Lollipop.
