03-14-2020 09:44 AM
27 12
tools
  1. 17021990's Avatar
    I figured it out - I'm not certain if you have to clear all paired devices first; however, if you hold down the multi-function (on/off) button for about 10 seconds or longer, the voice notification will say, "pairing" and the button LED will flicker; this process then paired with my Samsung Note 4! Good luck.
    That was very helpful my friend, thanks!
    08-04-2019 04:54 AM
  2. Beardoe's Avatar
    Thanks so much 😊 worked for me too!!
    03-14-2020 09:44 AM
27 12
  1. Can I get some help with my Flare S3 charging problem?
    By Akosi Irish in forum General Help and How To
    Last Post: 06-09-2016, 03:55 AM
  2. Should I trade my Note 3 for a Nexus 5? I Can't decide!
    By TheOriginalWolfman in forum Ask a Question
    Last Post: 04-12-2015, 04:37 AM
  3. Why does my S3 Plus drop wifi connection for certain apps?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 04-09-2015, 12:40 AM
  4. Why can't I update my LG G2?
    By AC Question in forum LG G2
    Last Post: 04-08-2015, 01:47 PM
  5. How do I stop my Note 3 Neo side bazel paint coming off?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 04-08-2015, 04:05 AM
