1. HeyMcFly's Avatar
    Just updated to 5.0, tried to go into "Sound and notification" in the settings menu, however whenever I touch it, Settings crashes. I've tried rebooting, wiping the cache partition, and clearing Settings data/cache. Any other suggestions?
    04-08-2015 08:43 AM
  2. sparksd's Avatar
    Sounds like a factory reset may be all that's left as you've tried the standard fixes already.
    HeyMcFly likes this.
    04-08-2015 09:00 AM
  3. MalinoisK9's Avatar
    No one wants to do a reset but it improved my phone so much after the update. Use keis and 90ish percent will be just as you left it when you restore.
    04-08-2015 09:55 AM
  4. karsdroid's Avatar
    yep, factory reset fixed it....annoying but at least solved, also solved my battery drain.
    04-08-2015 10:40 AM
  5. HeyMcFly's Avatar
    I just bit the bullet and reset. Fixed the issue. Thanks all.
    04-08-2015 12:55 PM
  1. Replies: 2
    Last Post: 04-09-2015, 06:52 AM
  2. Regular email notification
    By Patience Wolf in forum Ask a Question
    Last Post: 04-08-2015, 01:07 PM
  3. Replies: 2
    Last Post: 04-08-2015, 10:00 AM
  4. How do I turn off notifications on my Asus 701T?
    By AC Question in forum ASUS Transformer Pad TF701
    Last Post: 04-08-2015, 08:45 AM
  5. Replies: 1
    Last Post: 04-08-2015, 08:08 AM
