1. chiccop96's Avatar
    Hi everybody,
    In my note 4 every time I try to open the Samsung music player it crashes. I tried to clear the data in the setting and also a wipe cache but there is still the problem.
    What can I do?
    I'm still 4.4.4 because in my country Lollipop isn't still available.
    04-08-2015 05:12 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you get an error message, or does it just stop?
    Do you have an SD card inserted? If so, and if it's corrupt, maybe it's causing some issues. Try unmounting the card (in Settings>Storage​), remove it, and try again.
    chiccop96 likes this.
    04-08-2015 06:17 PM
  3. chiccop96's Avatar
    I get the error 'unfortunately music player has stopped'
    Yes, I have a micro SD but if I do what you told me I have always the same problem...
    04-16-2015 02:57 PM
  1. Is there a way to NOT have notification sounds interrupt music?
    By Blipstein in forum Samsung Galaxy Note 4
    Last Post: 11-16-2015, 10:49 AM
  2. Problem with moving Apps to SD card
    By Ricardo Paes in forum Samsung Galaxy S5
    Last Post: 04-11-2015, 09:06 AM
  3. Problem with new update L 5.1 NEXUS 5 what should I do?
    Last Post: 04-09-2015, 12:12 PM
  4. Reset problem
    Last Post: 04-08-2015, 04:42 PM
  5. Can I change the alarm clock music on an LG L34C Optimus Fuel?
    By AC Question in forum LG L Series III
    Last Post: 04-08-2015, 04:37 PM
