1. MaxEvans's Avatar
    I changed the ssid and password, But now Eventing can't connect. What am I doing wrong? I do this on routers and it works fine. But not on my phone.
    04-09-2015 03:38 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Were you able to connect other devices to your phone's hotspot before you changed the SSID and password? If so, then make sure you forget the network on the devices you're using to try to connect to the hotspot, then connect again and enter the correct password.
    If it has never worked for you, then are you sure your data plan includes hotspot usage? It usually requires an extra fee (or more expensive plan).
    04-09-2015 06:28 PM
  3. MaxEvans's Avatar
    Yes it worked before I changed that. Credentials. But after I changed them, my laptop says it can't connect, and my tablet never connects.
    04-09-2015 07:01 PM
  4. MaxEvans's Avatar
    I got it working I tweaked with the settings and got it. Thanks for the help.
    B. Diddy likes this.
    04-09-2015 07:39 PM
  1. Replies: 2
    Last Post: 05-17-2016, 12:39 PM
  2. Problem with automatically restarting background apps
    By Pawel Sawicki in forum Android 4.4 KitKat
    Last Post: 08-04-2015, 12:36 PM
  3. Why is there a slash going through the clock on my screen?
    By Hala Beirouty in forum HTC One M7
    Last Post: 07-15-2015, 04:02 AM
  4. Replies: 5
    Last Post: 04-15-2015, 11:47 AM
  5. Can I have two dialers on the same phone?
    By relztrah in forum General Help and How To
    Last Post: 04-09-2015, 03:35 PM
