1. br808's Avatar
    There are a few things I find lacking w/ lollipop.
    For starters, instead of pressing the power button to access the sound/mute buttons, I now have to unlock the phone an decrease the volume. And that doesn't even turn off vibrations like mute did. (I went and turned off vibrations for all notifications)
    What happened to the app w/ the number where you can turn apps off?
    Also, a folder with apps in it disappeared? It's not a big deal, I recreated the folder and replaced the apps, but why did that happen.
    I really don't see any benefit. It's not faster than KK (in fact it's slower in some regard)
    Anyway, if I could get that mute back on the lock screen, that'll be great.
    fryerlawrence likes this.
    04-09-2015 10:40 PM
  2. Lepa79's Avatar
    Pulling down the notification panel and using the toggle button doesn't work for you?
    04-09-2015 11:05 PM
  3. br808's Avatar
    that works, but I'd rather not have to unlock the phone to mute it
    thanks for the reply
    04-09-2015 11:08 PM
  4. dpham00's Avatar
    You can install power toggles from the play store and setup the sound toggle to appear on the lock screen.
    You can add the active applications widget to add the "app with the numbers"
    You might see better performance after a factory data reset, especially after a major os upgrade
    04-09-2015 11:19 PM
  5. Lepa79's Avatar
    Just an idea. I have smart lock on, so when I'm at "trusted" places like home, the notification pull down on the lock screen works without having to unlock the phone. So u can mute fast and easy.
    04-09-2015 11:44 PM
  6. bassplayrguy's Avatar
    On my lock screen I can pull down the notifications and mute my phone without unlocking and Lollipop is a lot faster than KK. You really need to do a factory reset after installing a new operating system or a massive update.
    br808 likes this.
    04-10-2015 08:17 AM
  1. Lockscreen clock size after Lollipop
    By Alice Stribling in forum Samsung Galaxy S4
    Last Post: 06-01-2015, 09:02 PM
  2. Galaxy Tab S no longer recognizes decrypt password shortly after Lollipop update
    By ColorConfinement in forum Samsung Galaxy Tab S 10.5
    Last Post: 04-11-2015, 04:57 AM
  3. New LG G3 Lollipop Issues?
    By Ryche in forum LG G3
    Last Post: 04-10-2015, 09:29 PM
  4. evolve and notifications on lollipop
    By tennislvr8 in forum Android Apps
    Last Post: 04-09-2015, 10:36 PM
  5. Play services crash upon restart since lollipop update
    By jkayakj in forum Samsung Galaxy S5
    Last Post: 04-09-2015, 08:41 PM
