With KitKat screen was always on top of the list.
What your battery options say?
Sent from my mobile device
I think lollipops battery burn report is hosed. GSam is reporting entirely different results. The GSam results are what you would expect, the lollipop results make no sense.
Battery report is complete bunk. I haven't used Tweetcaster at all and its notifications are off. Screen isn't even on the list even though it usually is about 4th on the list. That said, my battery life is nothing short of awesome.
My battery life on Lollipop is all over the place. Either the battery is incredible and takes a lot of use to drain, or it will mysteriously drop 50%+ over 3 hours of sitting idle with no use. It's a total crap shoot on what I get from one day to the next. I've found that restarting the phone each morning helps the drain to not occur, but I never that issue with KitKat.
When I investigate, the culprit is always Android System.
