How do I get the Charge Boost screen to appear when charging my Note 4?
  • Start date Start date
A
AC Question
My wife and both have the Note 4 and after the lollipop update when she charges her phone she gets a separate screen that pops up and I believe its called a charge boost sreen. It tells how much time is remaining to charge the phone and has a few other features.
I spent hours trying to figure out why she has it and I dont. I have googled it and looked around the forums but cant find it anywhere.
I believe this is the screen he is speaking about. I installed something ( have looked and looked and can not find out what it was.) I was asked if I wanted the boost screen on, I clicked yes, and this is the screen I get. After I swipe my screen, this screen shows up while charging. I have a 10,000 mAh battery, and from 10 to 15% it fully charges with nothing turned off to full 100% in about 4 hrs now. Down from 5 to 6 hrs before. Well, I can see where to add a photo of the screen. Please let me know, and I will gladly add the screen shot. SGM Brian Davis US Army (Ret)
Re: How do I get the Charge Boost screen to appear when charging my Note 4
I would add the oic, but every time I try, this site shuts down. I hit "report", so we will see. Will try 1 more time after posting this.
I think the app CM Locker has this feature. I used to have it and whenever it updates I have to turn that feature back on in settings
there is an application called "omni swipe" in Google Play store! I worked there and I that function! I hope to be that which you ask. boost charge!
You may be referring to the Clean Master Charge Boost. Open Clean Master, select the "Me" icon on the bottom of the page then Settings then toggle On/Off Charge Boost Lock Sceen
i know how it appears... just go to settings then Date and time and turn off Automatic Time zone.. when you turn it off Charge Boost screen appears on the lock screen..
How do I find this clean master on my phone. I want this boost charge gone
Diokulkyta
