1. shaleem's Avatar
    I don't know what I did. I pressed volume up, power, and menu buttons together to do a cache wipe. Instead I got the following : Downloading... Do not turn off target.
    In the top, left corner it says, in this order:
    ODIN MODE (high speed)
    Product Name : SM-N910A
    System Status: Official
    Reactivation lock : off
    Knox warranty void : 0x0
    Qualcomm Secureboot : Enable (CSB)
    AP SWREV : S1 T1 R1 A1 P1
    Secure Download: Enable
    UDC START
    I have no idea what I've done. As I said, it says Downloading. What should I do?
    04-14-2015 11:33 PM
  2. naira1's Avatar
    Just remove the battery and put it back in. I think you pressed the volume down and not up in the combo that's why it happens. But no harm done. Just off and on the phone again.
    Edit: while you are on the screen you described, you can also just click the volume down to cancel. So no need removing the battery unless as last resort
    Rukbat and shaleem like this.
    04-14-2015 11:38 PM
  3. Rukbat's Avatar
    In case anyone reading this has an S6 (or other phone you can't remove the battery from), holding the power button down for about 30 seconds will do the same thing.
    shaleem likes this.
    04-14-2015 11:41 PM
  4. shaleem's Avatar
    Thank you very much. I was in a panic!!! All is as it should be.
    Posted via the Android Central App on my Samsung Galaxy Note 4
    04-14-2015 11:45 PM
  1. Replies: 2
    Last Post: 04-10-2016, 07:09 PM
  2. Replies: 1
    Last Post: 04-16-2015, 12:08 AM
  3. Samsung Galaxy S3 i747 (4.4.2) AT&T Root Help
    By Jesse Del Villar in forum Samsung Galaxy S3
    Last Post: 04-15-2015, 12:11 AM
  4. power saving mode helps battery
    By robinhelenehebert in forum Samsung Galaxy S6
    Last Post: 04-14-2015, 06:47 PM
  5. Help Please! Kies=Smart Switch now, doesn't work on Desktop
    By GregMargie in forum Samsung Galaxy Note 4
    Last Post: 04-14-2015, 05:56 PM
