1. sstephen17's Avatar
    Ever since I got the Lollipop upgrade, my battery life has suffered significantly. On a typical day, (unplug at 7A, plug in at 11P), I used to finish with about ~30%. Now, I'm lucky if I get to ~15%. On heavy use (lots of texting typically), I cannot make it through the day without recharging or swapping batteries.
    I did a couple of cache wipes and phone restarts but that didn't help. Decided to do a factory reset. I think that may have made it worse but if anything, it stayed the same. Has anyone else done a factory reset and not noticed any change to battery issues? I did mine via the "Backup and Reset" under phone options. Should I have done it via the bootloader?
    04-16-2015 07:33 PM
  2. sstephen17's Avatar
    Don't want to downgrade as I do like the phone's speed on Lollipop as well as a couple of other handy improvements. I'll see how it goes for a couple of days without doing daily cache wipes and resets.
    04-17-2015 11:58 AM
  3. Gunny94's Avatar
    You checked for any background applications that are eating up your battery?
    Also can you upload battery stats after a day?
    04-17-2015 12:26 PM
  1. Replies: 2
    Last Post: 04-18-2015, 12:17 AM
  2. Why is my Galaxy S3 switching off when I turn wifi on?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 04-17-2015, 04:26 PM
  3. Replies: 2
    Last Post: 04-16-2015, 11:59 PM
  4. Is the Verizon S6 still global?
    By Gav508 in forum Samsung Galaxy S6
    Last Post: 04-16-2015, 10:34 PM
  5. Replies: 0
    Last Post: 04-16-2015, 07:18 PM
