Kelly Kearns
Has anyone heard of S health causing it? That's about the only Samsung app I use and one of the few I haven't troubleshot because I don't want to give up the pedometer. This issue has followed me through 2 Note 4s (replaced one) and many, many factory resets. Even sync off doesn't fix the issue.
I have S Health disabled. I use Google Now but don't have much on it.
Yeah power saving is WiFi and GPS. I never turn my WiFi off, I had the same issue as you with my S5. I thought at first there was a bug and the WiFi line never showed it off. I finally tracked down the app doing it, but don't remember what it was.
Also do you have a Samsung account that is syncing anything? It might take running through all the apps showing up in "apps" and "data" in the battery graph. You have something that is reporting your location a lot or syncing a lot.
Also, I remember reading this, you can go to your Google settings and delete location history. That and using less than high accuracy for location, can help. I also deleted location history, but I don't even want a location history, don't know if you do through.
