Re: OK....I am REALLY REALLY CONCERNED about this!
So you are saying for you when you are on Wi-fi, the 4G LTE doesn't light up?
For factory reset...how did you take a back up? Helium backup? problem is i have some apps I can't take a back up for some reason, and i loose all tht app data!
I have not experienced this issues. I did a factory reset three days after the Lollipop update. I would suggest anyone who is having problems do a factory reset. If it doesn't help than use your warranty insurance and replace the phone.
