08-25-2016 08:34 AM
51 123
tools
  1. Android D's Avatar
    On Note 4 with Verizon...Since the Lollipop update, we all know now that 4G LTE lights up along with Wifi..
    My Concern is...And I am Convinced this is the case...Even though when I am connected to Wifi, 4G LTE is still being used. I just made a call on fb messenger app to my friend, talked for like 40 mins, entire time on Wifi, checked my Data usage 2hrs later and it went UP BY 30 MB!
    This is absurd...is this really a BUG in Lollipop now from verizon? Verizon is recommending I turn off the Data everytime I am on Wifi, I tried setting up a tasker profile for it but it's not working for me!
    Please any Suggestions appreciated!
    Tatt2014 likes this.
    04-19-2015 06:51 PM
  2. Techno-guy's Avatar
    Oh man...that really bites! I just checked my data usage on T-Mobile for my S6 (for comparison purposes) and it's not using LTE when on WiFi. I'm sure because I downloaded a good bit of music today while on WiFi but it did not hit my data.
    I'm on Lollipop 5.02. Not sure what version you're on or what Verizon could have done to affect it.
    04-19-2015 07:25 PM
  3. kami8586's Avatar
    I have noticed this too, also on Verizon. Interesting
    04-19-2015 07:28 PM
  4. Tatt2014's Avatar
    Same here on Verizon, love lollipop update,but since I have installed it on my note 4,the data has almost doubled compared to what we usually use, we usually never go over 3 gb a month and with 2 days left before my 10 gb data allowance starts over we have used almost 6gb,just glad I have the 10gb plan. Good luck to all of us😯
    04-19-2015 07:45 PM
  5. Neo_ii_Droid's Avatar
    I don't know if this works:
    Settings>More networks>Mobile networks>Mobile data (uncheck the box)
    Maybe it'll work?
    04-19-2015 07:51 PM
  6. Neo_ii_Droid's Avatar
    Here's what pops up.
    Attached Thumbnails WiFi and 4G LTE on at the same time?-screenshot_2015-04-19-16-50-38.jpg
    04-19-2015 07:53 PM
  7. juliesdroidsync's Avatar
    Are you using download Booster? If so, then it is functioning as designed and as intended. But you can turn that off in settings pull down menu
    04-19-2015 08:47 PM
  8. juliesdroidsync's Avatar
    Here's a screenshot, just make sure download Booster is off
    Attached Thumbnails WiFi and 4G LTE on at the same time?-screenshot_2015-04-19-19-48-11.jpg
    Jamie Wooten likes this.
    04-19-2015 08:49 PM
  9. kirksucks's Avatar
    Facebook app inexplicably used almost half a gig in like 4 days. I disabled it.
    04-19-2015 09:05 PM
  10. Android D's Avatar
    I contacted Samsung and they said the Same thing...turn off the Download Booster...and tht I have never touched that thing honestly, so it's been off the whole time!
    04-19-2015 09:12 PM
  11. Android D's Avatar
    Maybe it'll work?
    basically wht u r suggesting to switch off data when I am connected to Wifi...and tht's wht verizon told me too..I guess tht's the only way out. But as i said, it's a pain to turn it off and on especially if you leave your wifi zone like 20 times a day...tht's why I designed a tasker profile to do it automatically for me, but it doesn't seem to work!
    04-19-2015 09:13 PM
  12. Android D's Avatar
    So u are saying I just flat out disable the FB and the FB messenger app??
    tht way I won't be able to get any notification from any of those apps though..I don't like tht.
    04-19-2015 09:14 PM
  13. Android D's Avatar
    Can anyone think of a Tasker profile to turn this Data off when u r on Wifi..and turn it back on When u leave the Wifi...I have tried, and honestly it's a Simple profile to set up, but It fricking doesn't work for me!! ugh..
    04-19-2015 09:15 PM
  14. Android D's Avatar
    I am with 5.0.1 WIth verizon..
    For your use, check about 2 hrs after your activity..the thing is the usage doesn't reflect right after your activity..when I made tht call with FB, i checked right away, no change in Usage...2 hrs after, and I know i didn't do anything tht would use 30 MB of data, and I see that my usage climbed up by 30 MB...all i can think of is tht FB call...During the entire call, I was keeping an eye on the 4G icon and I saw it was lighting up...Even though as I mentioned I was on Wifi during the entire call!
    04-19-2015 09:18 PM
  15. Neo_ii_Droid's Avatar
    I would not know how to read this for mine.
    By the way, I too am on VZW with the Lollipop update.
    04-19-2015 09:55 PM
  16. Android D's Avatar
    http://i987.photobucket.com/albums/a...psob3x5fs7.jpg
    http://i987.photobucket.com/albums/a...ps4s9oa9il.jpg
    Lol yeah honestly this whole graph thing is jack..It don't make one bit of sense to me!
    04-19-2015 09:57 PM
  17. carraser891's Avatar
    I'm on Verizon and have the 4G icon lit all the time on WiFi and notice no data usage. the arrows only light up when I receive a call or text.
    04-19-2015 10:17 PM
  18. Rmedy21's Avatar
    I've been noticing the same thing. I've been on WiFi all day and apparently it's eating my data thank goodness I have a 10gig plan
    04-19-2015 10:23 PM
  19. Android D's Avatar
    Hmm...I don't know wht to make of it..Some ppl are reporting here that it's not effecting them, while others are reporting tht they, like me, have seen an increase in their data usage!
    I guess I can only point this to a app specific problem then? may be that Fb messenger app was using Data all tht time I was on the call even though I was connected to Wifi ??
    04-19-2015 10:31 PM
  20. Android D's Avatar
    Lucky u dawg!
    04-19-2015 10:32 PM
  21. Andy847's Avatar
    I'm not on Verizon anymore, thank God, I left them for ATT. I disabled Facebook app right away on my Note 4 on Verizon and on N4 on ATT. I just use the browser on the phone to get on to Facebook. If it's the App that's doing it, just try going through there instead of the app. Just a Suggestion. I still get notifications on my page.
    04-20-2015 12:04 AM
  22. juliesdroidsync's Avatar
    I read on another post something that might be appropriate to add here... Have you turned on advanced calling? On another post where someone was using a lot of data, supposedly Verizon told them that it was part of Smart Switch. so this person also had advanced calling turned on. Advanced calling does use some data while you are on a phone call, apparently. And, in something that might be a bug, I'm wondering if that is happening all the time. if you can, if you have advanced calling turned on, turn it off and see if your problem goes away. I would be very interested to know the answer to that. I'm sure a lot of other people would be very interested.
    04-20-2015 12:17 AM
  23. nugj's Avatar
    Well so far I have just not performed the update. Frankly if I could just get rid of the update reminder screen I would just wait longer. I am Note 4 user on VZW and I am be darned if I am going to see my data sucked up by this stupid thing. If they can't get these updates right, why bother with them. They are more trouble than they are worth.
    It sounds like they can't even give us a straight answer regarding what is wrong.
    04-20-2015 12:26 AM
  24. jakeypride's Avatar
    Good thing I have unlimited data with verizon 👌
    Rmedy21 likes this.
    04-20-2015 01:59 AM
  25. Flinthills's Avatar
    I've noticed increased data usage but thought I forgot to turn on wifi.
    04-20-2015 02:40 AM
51 123
  1. Replies: 27
    Last Post: 12-15-2017, 08:23 AM
  2. How can I download directly to the SD card on my tablet?
    Last Post: 09-02-2015, 11:49 AM
  3. Replies: 8
    Last Post: 07-03-2015, 01:16 AM
  4. Why do I have a strange screen on incoming calls?
    By YossiN in forum General Help and How To
    Last Post: 04-20-2015, 11:49 PM
  5. Preview of title thread on Tapatalk notifications?
    By 6FtHook in forum Ask a Question
    Last Post: 04-20-2015, 04:48 PM
