enable battery saving when battery reach %
al404
12
i not sure if this feature was on previous samsung model but on some other phones it is possibile to auto switch ON power saving mode if battery gets lower than X %
is not available on note 4?
Nitro211K
321
18
Good news - yes you can, bad news - not easy to do, and not with Touchwiz. To get to that setting you will have to use a launcher like Nova and access the shortcut/activities/setting/power saving mode and the one with green icon (in my screen shot). I was able to set mine to 15% but there is also a 5% option.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Or just leave power saving on all the time, except when you need extra strength. About all normal power saving does is limit the maximum CPU speed.
pierre5463
