1. jakeypride's Avatar
    How do I get rid of the gap between the search bar and notification bar? Please help!
    04-22-2015 05:49 PM
  2. Rod Ruppenthal's Avatar
    Use Nova Launcher. You can allow widgets to overlap
    04-22-2015 05:52 PM
  3. jakeypride's Avatar
    This is nova, sorry for the confusion.
    04-22-2015 05:56 PM
  4. Nitro211K's Avatar
    Yes, but based on your screen shot, i don't think you are not in Nova yet. Once you are in Nova, you can long press the search bar and resize it, and such.
    Ntchwaidumela likes this.
    04-22-2015 06:01 PM
  5. Nitro211K's Avatar
    You should get this. (Using the 4x4 widget)
    Ntchwaidumela and jakeypride like this.
    04-22-2015 06:19 PM
  6. joediver's Avatar
    As long as you set Nova to allow overlapping widgets
    04-22-2015 09:36 PM
  7. jakeypride's Avatar
    Thanks so much guys!
    04-22-2015 09:46 PM
  1. Replies: 2
    Last Post: 02-24-2016, 01:54 AM
  2. Replies: 6
    Last Post: 04-24-2015, 03:44 PM
  3. Google Play Music is launched by Words with Friends?
    By mumfoau in forum Ask a Question
    Last Post: 04-23-2015, 08:51 PM
  4. Color change for android system on note 3 with lollipop 5.0
    Last Post: 04-22-2015, 10:43 PM
  5. Can I get some Battery Help?
    By KC5429 in forum Samsung Galaxy S6
    Last Post: 04-22-2015, 03:27 PM
