1. AC Question's Avatar
    I have my note 4 since release but recently my battery have been dying very quickly . I only have 2 and half hour on screen time. I checked my screen useage only to find out that it has 42% useage. Is there anyway to keep it down
    (Sorry i have a bad grammer and thank you)
    04-27-2015 10:35 AM
  2. Mom2Ninjas's Avatar
    Dim your brightness. Use dark backgrounds when you can.
    04-27-2015 06:03 PM
  3. MedicD's Avatar
    There are a ton of things that could cause this. Post your battery stats screenshot and click on the graph then post that screenshot too
    04-27-2015 11:26 PM
  4. Racinghart91's Avatar
    i have the brightness at 100%
    i get one hour of screen on time per 20% battery, so after 1 hour my battery is at 80%.
    at the end of the day i have 40% left with 3 hours of SOT, not bad IMO
    geekaren likes this.
    04-28-2015 06:48 AM
  5. MedicD's Avatar
    If you had 2.5 hours screen time and 40% left then you're not too far off of what most people are getting. Recently I'm lucky if I break 5 hours screen time in. A day. Something in android keeps waking up all the time.
    04-29-2015 07:31 AM
  6. Gunny94's Avatar
    Yeah, pretty much what MedicD said =)
    If you just installed Lollipop, I recommend a reset factory if you notice battery drain.
    MedicD likes this.
    04-29-2015 07:35 AM
  7. Pdarnall's Avatar
    Reset. Once that's done start disabling applications.
    04-29-2015 09:29 AM
  8. MedicD's Avatar
    As a followup... for some reason some of us get between 3 and 5 hours, then there are some that consistently get 6 or 7 hours and 2 days of usage. My phone is waking constantly and I can't figure out why, I've tried 3 factory resets. Some just seem better than others
    05-17-2015 08:16 PM
  1. I lost my lolliepop update.
    By litchie in forum Ask a Question
    Last Post: 05-06-2015, 06:49 PM
  2. Replies: 1
    Last Post: 04-28-2015, 01:04 AM
  3. Replies: 1
    Last Post: 04-27-2015, 07:08 PM
  4. My gallery app disappeared, where can I go to find it?
    Last Post: 04-27-2015, 01:43 PM
  5. Replies: 1
    Last Post: 04-27-2015, 11:52 AM
