1. bassplayrguy's Avatar
    For some reason I cannot enable the smart lock feature. Is this not available on ATT? I tried going to trusted agents but that is greyed out as well. Any advice?
    04-28-2015 09:11 PM
  2. Kelly Kearns's Avatar
    I can turn mine on and my trusted agents aren't grey. I had another issue though and it had to do with security and it had some options greyed out. I was on the phone with Samsung for an hour and I finally figured this out and tried it. My issue was different, but it had to do with this same security tab so you can try this.
    I had credentials stored that blocked me from turning my unlock to swipe for a few minute. Try hitting this to clear and see then if it will let you use smart lock.
    04-28-2015 09:17 PM
  3. Oilfield Trash's Avatar
    Setup a pin for your lock screen, then you'll be able to use smart lock feature
    Sent from my SM-N900V using Tapatalk
    Ntchwaidumela likes this.
    04-28-2015 09:22 PM
  4. bassplayrguy's Avatar
    Thank you!
    04-28-2015 09:31 PM
  5. Kelly Kearns's Avatar
    It didn't think about that, I just went on the assumption that everyone has a secure lock on their phone. It took me years to do that, but with more and more available on my phone now, a secured lock is the first thing I do.
    04-29-2015 02:10 AM
  6. Diane Kennedy's Avatar
    I'm having the same problem on my Galaxy Note 3 (AT&T). I tried the Clear Credentials step, but it's still greyed out. I've had a pin code on my device since I bought it. Is there anything else to try?
    06-26-2015 10:48 AM
  1. Replies: 16
    Last Post: 09-01-2016, 09:57 AM
  2. GS6E on T-Mobile missing Smart Lock?
    By Phoenixfury in forum Samsung Galaxy S6 edge
    Last Post: 06-11-2015, 09:23 AM
  3. Any shutterbugs out there?
    By Golfdriver97 in forum LG G4
    Last Post: 05-03-2015, 11:08 AM
  4. Can't get out of App section in play store
    By joey5677 in forum Ask a Question
    Last Post: 04-29-2015, 12:41 AM
  5. Replies: 2
    Last Post: 04-28-2015, 07:43 PM
