would you still get it if it's sealed, and had similar aesthetics to the S6, better camera, finger print scanner, etc?
what size battery would it have to be?
I don't expect the battery to be sealed, and I think it'll come with SD, but I wouldn't be shocked if it follows the S6. Personally, I'd probably go with the Nexus 2015, unless the Note 5 has a replaceable battery or a sealed 3400+ mAh.
