1. LumiaIcon's Avatar
    To keep this simple. I am on AT&T. I wish to purchase a Galaxy Note 4 and install CyanogenMod which I understand I cannot do on AT&T because the boot loader is locked. What model number or model numbers will accomplish this? Will I be able to get LTE speeds on AT&T or have any major compatibility issues? Or... is this simply not easily done?
    04-29-2015 04:46 PM
  2. Kelly Kearns's Avatar
    I think the T-Mobile version is the only one rootable.
    Now on xda with the S5 they did discover you could root KitKat and then use a specific way to update your rooted S5 to Lollipop.
    Now in glancing, that might can be done with the Note 4 also. I want to say the user that discovered the way to do this is named chainfire, something like that. If you search at xda, you can find out if you can do this with the N4.
    Any N4 you buy right now will still have KitKat out of the box, so if you can root the AT&T N4 and update to Lollipop the same way you can with the AT&T S5, then it won't be a problem for you to buy an AT&T one.
    04-29-2015 05:22 PM
  3. Kelly Kearns's Avatar
    Eventually the AT&T one will be rootable, they are working on it at xda and making progress.
    04-29-2015 05:22 PM
  4. Rukbat's Avatar
    Most people use the European model - the 910F. You won't have compatibility issues with 4G until AT&T does away with Band 17 - which won't be for a long time. No locked bootloader either. Whether CM12 will have issues with AT&T is another matter, and something I can't answer.
    LumiaIcon likes this.
    04-29-2015 05:23 PM
  5. Rukbat's Avatar
    He's not asking about rooting, he's asking about flashing Cyanogen, which you can't do on an AT&T or Verizon Samsung. The bootloader has nothing to do with rooting.
    04-29-2015 05:25 PM
  6. Kelly Kearns's Avatar
    The locked bootloader is why the AT&T can't be rooted.
    Correct me if I'm wrong, but that is a custom ROM is it not and don't you have to be rooted to flash a ROM?
    04-29-2015 05:29 PM
  1. Replies: 3
    Last Post: 05-09-2015, 03:51 PM
  2. Google Play Movie Rental *FREE*
    By deeb215 in forum Samsung Galaxy S6
    Last Post: 04-29-2015, 11:51 PM
  3. APN HELP
    By wyteryno in forum General Help and How To
    Last Post: 04-29-2015, 02:14 PM
  4. Help: S6 edge screen is not working
    By Sadeq Althawab in forum Samsung Galaxy S6 edge
    Last Post: 04-29-2015, 01:40 PM
