1. Rmedy21's Avatar
    I don't know why this keeps popping up.
    Attached Thumbnails Need your help Note 4-screenshot_2015-04-30-01-53-32.jpg
    04-30-2015 12:55 AM
  2. SpookDroid's Avatar
    Do you have any cables connected to you device at the time (via the USB port)? If not, there's probably a false-contact happening in the USB connector. You can try cleaning it with a soft, dry brush or by blowing air into the port (it's better if the device is off when doing this), but if it keeps happening, I'd get the unit replaced or repaired while it's still in warranty since it can be a loose connector or something that's creating a 'bridge' between contacts that shouldn't be bridged, and that could lead to further damage.
    04-30-2015 01:02 AM
  3. Rmedy21's Avatar
    Do you have any cables connected to you device at the time (via the USB port)? If not, there's probably a false-contact happening in the USB connector. You can try cleaning it with a soft, dry brush or by blowing air into the port (it's better if the device is off when doing this), but if it keeps happening, I'd get the unit replaced or repaired while it's still in warranty.
    No I don't have anything connected
    04-30-2015 01:03 AM
  4. SpookDroid's Avatar
    Definitely a false contact. Similar thing happened to a friend's S3 and it kept popping up the message that it was being connected to a car dock. Cleaned it with a brush and the problem was gone.
    04-30-2015 01:06 AM
  5. Rmedy21's Avatar
    Thanks I will try that
    04-30-2015 01:06 AM
  1. Why can't I update from the Play Store on my Galaxy Note 4?
    By Stanley Nande in forum Samsung Galaxy Note 4
    Last Post: 04-30-2015, 08:22 PM
  2. Note 4 SM-N910T T-Mobile
    By PainFX in forum Samsung Galaxy Note 4
    Last Post: 04-30-2015, 12:29 PM
  3. Replies: 3
    Last Post: 04-30-2015, 05:54 AM
  4. Replies: 1
    Last Post: 04-30-2015, 05:20 AM
  5. Will I get the Lollipop update for my unlocked AT&T Note 4?
    By utkarsh singh5 in forum Legacy Android & Other OS's
    Last Post: 04-30-2015, 01:07 AM
