1. AC Question's Avatar
    Ok, I have had my galaxy note 4 (at&t) for a few months now, and things were rather peachy at first. I liked the phone and the battery life was ok. Alas! As of late, my phone literally, and I am dead serious, loses ridiculous amounts of battery right before my eyes. Like 2% every minute and and a half. i went from 79% to 36% in an hour and a half. And this is not continous use, this is me using it, putting it down, and picking it up again. I've literally done everything in my power to help the battery but it doesn't work. Plz help me.
    04-30-2015 06:36 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Did this start after the Lollipop update?
    It would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    04-30-2015 06:42 PM
  3. FSU30's Avatar
    Ahhh. Same here. Moreso noticeable after the lollipop update. *I HAVE done the 'clearing the cache thing,' but really really do not want to do the factory reset.
    Note 4 (Verizon), Lollipop, 128GB micro D
    Attached Thumbnails Why does my Note 4 lose battery so quickly?-screenshot_2015-05-01-13-03-11.jpg
    05-01-2015 12:09 PM
  4. FSU30's Avatar
    I'm following your post to see if there is someone out there that may know of how to help.
    05-01-2015 12:10 PM
  5. ELHHLE's Avatar
    Install GSam then run for a day and post the main GSam screen and the App Sucker screen. That will provide more detailed info. The lollipop battery reports are not very useful.
    05-01-2015 12:38 PM
  6. maduro78's Avatar
    Plus 1
    Moto X 2014
    05-01-2015 12:41 PM
  7. B. Diddy's Avatar
    Facebook can be a total battery suck, especially older versions--is it up to date?
    Also, corrupt SD cards can drain battery by causing the media scanner to get stuck on the corrupt file. Unmount the card in Settings>Storage, remove it, and reboot. Insert the card into your computer and run chkdsk to look for bad sectors: http://forums.androidcentral.com/amb...d-sd-card.html
    05-01-2015 01:45 PM
  1. Why can't I see the video on my PC from my S6 Samsung?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-23-2018, 02:00 PM
  2. I want to access the internet
    By Eliz7212 in forum LG G2 Rooting, ROMs, & Hacks
    Last Post: 05-02-2015, 12:13 PM
  3. Replies: 1
    Last Post: 04-30-2015, 07:00 PM
  4. How to reset picture source for text messaging?
    Last Post: 04-30-2015, 06:58 PM
  5. Will the Sd card from my S3 be compatible in an S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-30-2015, 05:12 PM
