1. AC Question's Avatar
    So recently I've had some issues with the camera delay. When I record any videos on my note 4 the videos lag in the sound. It does it even when I use external apps like instagram and snapchat. I've tried downloading another camera app to see if it was just the app itself but the other ones I've tried do the same thing.
    I've also tried to go into camera settings and clear and reset everything and still nothing has changed.
    Does anyone else have this problem with their note 4???? It is really starting to bother me...
    05-03-2015 05:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you copy the video to the computer and play it there, is the audio still out of sync?
    Try wiping the cache partition, if you haven't already: https://support.t-mobile.com/docs/DOC-14686
    05-04-2015 01:42 AM
  3. Jessica Ortiz2's Avatar
    Yea I have already done this. I'll try to upload it on my computer and let you know if it still does this...
    05-04-2015 01:01 PM
  4. Jessica Ortiz2's Avatar
    wait nvm.. i actually didn't wipe the cache partition.. just did and it works like a charm now!! Thank you!
    B. Diddy likes this.
    05-04-2015 01:05 PM
  1. Replies: 6
    Last Post: 05-04-2015, 07:52 PM
  2. voice recognition problems when another app is loaded.
    By nickthorley in forum Android Wear / Wear OS
    Last Post: 05-04-2015, 01:53 AM
  3. Replies: 1
    Last Post: 05-03-2015, 07:42 PM
  4. Samsung apps
    By tennislvr8 in forum Android Apps
    Last Post: 05-03-2015, 06:30 PM
  5. Can I get some help removing fbi prism virus lock down on my Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-03-2015, 05:37 PM
