Samsung Note 4 - AT&T - Major Problems after 5.0.1 update (HELP)
Model - Samsung SM-N910A
Verizon - 5.0.1
Baseband - N910AUCU1COC4
Kernel - 3.10.40-4160876
Build - LRX22C
OK I updated to 5.0.1 and it seemed to cause issues.. So I did a Wipe Cache Partition - then went back and did again - then went back and wiped device ... let it load everything and did it again to make sure..
I have done this 5x in 3 weeks. ITs getting old..
I have problems with very poor battery life now
I have problems with apps locking up (Gallery and camera)
No I haven't loaded anything extra (more than what loads by default)
the phone just runs choppy and slow - apps lock up and crash - and it sucks
I called ATT and nothing is being done now
I called Samsung and they say Google knows of the issue and is working on it but nothing more they can do..
I called Google and they say they don't know of any issues and wont support it since it isn't a Google Phone..
UGGGG
What can I do..
thanks
Patrick
Verizon - 5.0.1
Build - LRX22C
UGGGG
What can I do..
thanks
Patrick
