1. qbngator's Avatar
    Stock Note 4
    All of a sudden, the S Pen will:
    1. Not close the Air Command icon(s) when I push the button on the S Pen, and
    2. Any action/icon chosen from the Air Command will take about 1:30 - 2 minutes to appear after I've tapped on it.
    Has anyone else had this problem? Any suggestions for a fix to improve responsiveness?
    Thank you.
    05-05-2015 10:28 AM
  2. natehoy's Avatar
    My "go to" response if you have not already done it is to clear the system cache. Takes a couple of minutes at most, no loss of data, and it tends to fix a lot of odd problems.
    05-05-2015 10:29 AM
  1. S4 Issues: Wifi and TouchWiz issues
    By samjna in forum Telus Samsung Galaxy S4
    Last Post: 07-22-2015, 07:44 AM
  2. Doing factory reset causes any issue??
    By Srikanth Sri1 in forum Google Nexus 5
    Last Post: 05-07-2015, 02:01 PM
  3. Is glare an issue for you?
    By shadow82x in forum Samsung Galaxy S6 edge
    Last Post: 05-06-2015, 12:31 AM
  4. Why is my HTC One M7 battery dying at 20+?
    By EBrett in forum HTC One M7
    Last Post: 05-05-2015, 08:05 PM
  5. S6 edge daydream issues
    By Ron Markiewicz in forum Samsung Galaxy S6 edge
    Last Post: 05-05-2015, 12:40 PM
