1. BullGuard8's Avatar
    I am trying to Root my Note 4 running this OS:
    N910CXXU1AOA2_N910COJV1AOA2_N910CXXU1ANL3_HOME.tar.md5
    I installed the OS and upon the initial setup after entering my email and stuff, the moment it started to redownload all my apps from the online backup cloud, I removed the battery
    Now I tried rooting it using this CF-Autoroot but this is what I get:
    <ID:0/004> Added!!
    <ID:0/004> Odin v.3 engine (ID:4)..
    <ID:0/004> File analysis..
    <ID:0/004> SetupConnection..
    <ID:0/004> Initialzation..
    <ID:0/004> Get PIT for mapping..
    <ID:0/004> Firmware update start..
    <ID:0/004> SingleDownload.
    <ID:0/004> recovery.img
    <ID:0/004> NAND Write Start!!
    <ID:0/004> FAIL!
    <ID:0/004>
    <ID:0/004> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
    any help?
    It is a SM-N910C international bought in Dubai, could that be the problem?
    05-11-2015 12:29 PM
  2. BullGuard8's Avatar
    I bought a One Click Root subscription and am awaiting for one of their tech support agents to login to my lappy and help me
    05-11-2015 12:58 PM
  3. anon(5719825)'s Avatar
    When I rooted my Note 4 after upgrading to Lollipop, the first step in the rooting process was supposed to fail. Did you continue to follow the instructions after it fails?
    05-11-2015 01:07 PM
  4. BullGuard8's Avatar
    yes after the fail I tried many times, tried restarting the phone by pulling the battery and putting it back in Download Mode but no luck. I am tried of this so I'll just see how this One Click Root goes
    05-11-2015 01:14 PM
  5. anon(5719825)'s Avatar
    I would not trust this one click place.
    Kelly Kearns and H3aTeRzz like this.
    05-11-2015 01:16 PM
  6. BullGuard8's Avatar
    I read a few reviews online and they seem to be legit, I am helpless as well as I got no help from forums I asked this same question a month back but can't find the thread, no luck
    05-11-2015 01:18 PM
  7. Kelly Kearns's Avatar
    These forums don't focus on Android Development.
    You will get plenty of help at xda, but, you need to read entire threads and really search before asking questions. They won't just answer a question that doesn't belong, the members will be snarky if you haven't searched on forums or read the entire thread and it was covered in the thread.
    BullGuard8 likes this.
    05-11-2015 01:21 PM
  8. anon(5719825)'s Avatar
    Well I had ZERO experience in rooting phones and was successful my very first try on my Note 4 and Note Edge. If I can do it, you can to. You really can't mess it up if you take your time and read each step a few times before going forward.
    Kelly Kearns and BullGuard8 like this.
    05-11-2015 01:21 PM
  9. BullGuard8's Avatar
    They were able to root my device!
    What they did that I did differently is disable the Activation Lock from the Settings / Security which I didn't do before
    anon(5719825) likes this.
    05-11-2015 01:37 PM
  10. anon(5719825)'s Avatar
    Happy it worked out. I had never heard of that place before. I hope you didn't pay much for that.
    05-11-2015 01:40 PM
  11. Kelly Kearns's Avatar
    Yes, that needs to be done.
    I also hope it wasn't much and they were legit. I don't like ANYONE having access in my phone. I only let AT&T and Samsung, sometimes remote into my phone, I try not to even let them do it if I can get by without them doing it.
    05-11-2015 01:49 PM
  12. BullGuard8's Avatar
    It cost me 40 USD but I was that desparate! that lollipop crippled my phone so much in terms of speed and battery and even with the security wipe / cache wipe it helped a bit but it was no where near the smoothness of Kit Kat! I feel like I just bought a new phone! Disabled Knox right away and never even saw the OS update!
    This is the correct root file if anyone needs it, the one I had earlier was wrong also: https://download.chainfire.eu/559/CF...xx-smn910c.zip
    05-11-2015 01:56 PM
  13. Kelly Kearns's Avatar
    $40 is still an ouch.. I had never rooted, decided to root my S5, after reading the thread for the AT&T S5 at xda, asking a couple of questions, it took me less than 5 minutes. I used TowelRoot to root mine.
    Do you have an international phone? Or a US branded phone with the carrier you are using?
    05-11-2015 02:02 PM
  14. Skinscrushcowboys's Avatar
    Hey, do you have a link to the root process? I have rooted all my prior devices using ODIN, but have left this one alone so far.
    Thanks!
    05-11-2015 03:21 PM
  15. BullGuard8's Avatar
    international, I don't mind paying for the Note 4 with Kit Kat that I have now! You don't understand the beauty and snappiness of Kit Kat until you have used Lollipop for a month like I did
    05-11-2015 03:58 PM
  16. Kelly Kearns's Avatar
    I thought that was what you had.
    Yeah I understand KitKat and Lollipop both, I've had both of them the last month, I just prefer Lollipop myself.
    05-11-2015 04:19 PM
  1. How do I get my email address off my phone?
    Last Post: 08-06-2017, 02:04 AM
  2. Why is the color in my Samsung tablet camera wrong?
    Last Post: 05-11-2015, 12:51 PM
  3. My phone says insufficient storage, how do I solve them?
    Last Post: 05-11-2015, 12:07 PM
  4. Can I save my HTC One m8 after getting water damage?
    Last Post: 05-11-2015, 12:05 PM
  5. Replies: 0
    Last Post: 05-11-2015, 12:00 PM
