1. Asmir Puhovac's Avatar
    OK so I tried to root my Nore 4 910F, followed the instructions on numerous sites (e.g. XDA-TV), but when I press the "Start" button in ODIN, it just says "Failed!" and in download mode on the phone it says "SECURE CHECK FAILED: RECOVERY". Am I missing something or is my bootloader locked?
    05-16-2015 05:49 PM
  2. mrcil20's Avatar
    Did you disable Reactivation lock? Many tutorials don't say about it specifically.
    05-17-2015 09:07 AM
  3. Asmir Puhovac's Avatar
    Is that a must? To answer the question, no I havent.. didn't think it would couse any problems when rooting and forgot all about it. Will try it tomorrow and see if it helps! Thanks for the tip!
    05-17-2015 06:58 PM
  1. Why won't my SMS work after the Lollipop update?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 05-29-2015, 03:23 PM
  2. Why is going on with my S5 ringer?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-16-2015, 11:10 PM
  3. Replies: 2
    Last Post: 05-16-2015, 08:02 AM
  4. Replies: 1
    Last Post: 05-16-2015, 07:43 AM
  5. Replies: 0
    Last Post: 05-16-2015, 02:17 AM
