1. glaustin's Avatar
    Hi Guys
    Just bought a GN4 (in the UK) and went to get new SD card. I bought a Scandisk 32gb Extreme MicroSDHC UHS-I card, speed up to 45mb/s 300x, but I'm not sure it will work. Can anyone tell me (Before I open the package) if this SD will work or should I change it?
    Any help appreciated,
    Gra
    05-22-2015 01:54 PM
  2. Joe Vile's Avatar
    Can't see any reason why not!
    05-22-2015 02:01 PM
  3. bertsirkin's Avatar
    I wouldn't use anything by a Samsung branded card. I have tried many brands, including high-end Sandisk cards, and the only one that works consistently is a Samsung branded card. Others have had similar experiences as well.
    05-22-2015 02:27 PM
  4. skatergirl's Avatar
    I just recently bought a Samsung card for my Samsung tablet to store Google movies. It is working great so far.
    05-22-2015 03:36 PM
  5. D Android's Avatar
    I would stay away from SanDisk, especially Extreme series. I had two fail on me for no apparent reason, constant unmounting and remounting, replaced it with a Samsung one and never had a problem since.
    Ntchwaidumela likes this.
    05-22-2015 03:56 PM
  6. NexusGirlX's Avatar
    I have a PNY card in my Note Edge and a Kingston in my Note 4. Both have been problem free.
    05-22-2015 04:15 PM
  7. M3Stang's Avatar
    I've been using a samsung one for many months. No problems.
    05-22-2015 05:40 PM
  8. LegalAmerican's Avatar
    I just got my Samsung Class 10 32GB Pro Sd Card delivered yesterday and moved over 1000 music files from one, onto a flash drive, and onto the new Samsung card and the files transferred incredibly fast. I was very impressed and I could be mistaken, but I swear the music sounds cleaner and richer after doing that. But that could be entirely in my head.
    05-22-2015 05:46 PM
  9. glaustin's Avatar
    Thanks. I read somewhere the UHS-I card wouldn't work in the GN4 as it wasn't comptible.
    05-22-2015 06:19 PM
  10. beh's Avatar
    Hi Guys
    Gra
    Yes this card will work fine. I use Samsung cards (both EVO and PRO) as well as ScanDisk UHS-1 Class 10 cards, and the Lexar UHS-1 extreme cards which are the fastest in class. They all work just fine, I have had no issues with any of these brands over the years in all available iterations. Additionally, ScanDisk has a life time warranty that will replace any card that fails. And, of course, anyone who is not automatically backing images and videos up on one or more of the free cloud services is just foolish.
    05-22-2015 11:48 PM
  1. Save Contact Cards Sent Via SMS
    By donotryon in forum Google Nexus 5
    Last Post: 05-23-2015, 04:54 AM
  2. Replies: 3
    Last Post: 05-22-2015, 04:07 PM
  3. S6 - Fast charger not working!!?
    By Chris Reed6 in forum Samsung Galaxy S6
    Last Post: 05-22-2015, 12:10 PM
  4. How can I find an LG G3 SD card on phone?
    By AC Question in forum LG G3
    Last Post: 05-22-2015, 11:59 AM
  5. Contacts Sync not working properly with Exchange
    By bigboi00069 in forum Google Nexus 6
    Last Post: 05-22-2015, 11:01 AM
