1. Anas Rizvi's Avatar
    I am unable to select None Option in Lock Screen.
    Please Help
    05-28-2015 10:57 AM
  2. Kelly Kearns's Avatar
    Please Help
    Go to security, scroll down to credentials, than tap "Clear Credentials" and then you can choose swipe or none for the lock screen.
    Anas Rizvi likes this.
    05-28-2015 11:02 AM
  3. Anas Rizvi's Avatar
    Thanks a lot it worked ☺
    Kelly Kearns likes this.
    05-28-2015 12:57 PM
  4. kobe008's Avatar
    If you need to keep the credentials for apps such as Foxfi the only workaround I found was to unlock your phone using the phone finder on Samsungs website. After using Samsung's site my screen is now set to Swipe, however the options are still greyed out on the Select Screen Lock page. Works fine for me tho.
    05-28-2015 12:58 PM
  1. Tried to downgrade, failed miserably.
    By aspiller1998 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 11-21-2017, 10:01 PM
  2. How to connect my Chromecast to my sound system?
    By AC Question in forum Google Chromecast
    Last Post: 06-27-2015, 12:27 AM
  3. Replies: 4
    Last Post: 06-14-2015, 09:38 PM
  4. Replies: 1
    Last Post: 05-28-2015, 02:41 PM
  5. Replies: 0
    Last Post: 05-28-2015, 10:17 AM
