1. Douglas Yarnold's Avatar
    I have lots of apps on my Note 4 SD Card, and am going to upgrade from a 32 to a 64gig Card.
    Should I manually move every app to the device storage first, install the new card, and then move those apps to the 64gig card, or is there a faster way to do it?
    Update:
    I ordered a 64gig MicroSD Card.
    However, the rep at the AT&T Store told me that formatting the SD Card for the Samsung Note 4 is not necessary, just pop it into the phone and use it.
    I'm getting conflicting opinions about whether I have to format the card to fat32, opinions?
    05-30-2015 10:02 AM
  2. t11rmh's Avatar
    That is how I have done it in the past.
    Posted via a kicking Note4 on Lollipop.
    05-30-2015 10:55 AM
  3. PlanetPluto7's Avatar
    I would copy from the old to the new on a computer and just stick it in. Long as the new is formatted FAT32.
    jhill110 likes this.
    05-30-2015 01:30 PM
  1. The Dual SIM Experience
    By Josh Exmoor in forum ASUS ZenFone 2
    Last Post: 12-11-2015, 04:19 PM
  2. Replies: 1
    Last Post: 06-09-2015, 05:45 AM
  3. When are you going to fix the Lollipop upgrade, it's terrible?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 05-30-2015, 10:28 AM
  4. Replies: 0
    Last Post: 05-30-2015, 10:01 AM
  5. Replies: 0
    Last Post: 05-30-2015, 09:41 AM
